1985 Porsche 911 Carrera Gets restored by Tru Shine Detailing of Knoxville TN - Honda-Tech
Old 02-09-2013, 09:34 PM   #1
Tru_Shine's Avatar
Default 1985 Porsche 911 Carrera Gets restored by Tru Shine Detailing of Knoxville TN
Hey Everyone,
This was a restoration type detail that I was excited to get my hands on. I am such a big fan of these old school Porsche's and when this owner called me to come out and look at it, I was right on it. Once I inspected the car I knew right away the potential that it had. We scheduled the car and two weeks later I arrived.
This write up documents the process and products used to revive this 1985 911 Carrera. Lets get this going.
Here is the car when I arrived
Lets start with the wheels. One of my favorite wheel cleaners is P21s wheel gel. It is a pH balanced wheel cleaner safe and any wheels, painted,polished,clear coated... any wheel.
And another Favorite for cleaning the wheels is the EZ Detail Brush and Wheel woolies.
After the wheels I pre-rinse the paint to knock off any heavy and loose debris
After the pre-rinse, I then give the car a foam bath. The foam bath is very functional, and not just for show. When the foam is applied to the surface it acts as a suspension for the dirt and also gives the surface lubricity. all of this helps keep your car swirl free.
After washing the car, I brought it inside to inspect the paint under good lighting. this shows the tru surface and lets me know what I'm dealing with.
here are some pics under halogen lights which imitates what you would see under direct sunlight. the paint was very swirled and oxidized.
21 years of crust and residue build up around the emblems
So I finally got to work on the paint and begin the revival.
here is a picture of how much oxidation was removed.
Here is a before of the passenger door handle.
And here is the after
Rear Quarter Panel Before
Rear Quarter Panel After
For this next part, I noticed the emblem had 20+ years of crud built up around it, so I decided to remove the emblem to clean it underneath.
While making my way around the car, I found myself at this faded whale tail wing in the back. I knew that I could bring it back, so I taped off the surrounding areas and began to revive the paint
I also decided to paint the faded back air vents
here is a 50/50
and here was the final outcome
Here is another before and after of the Driver Quarter
On this door, not only did I polish out the scratches, I touched up the chips on the edge too.
These pictures are up close of what actually happens in Tru paint correction. The clear coat is leveled out removing the defects and not hiding them with glazes and waxes
Now for all the faded trim and plastics, I used a product that is a nano crystalized coating that has 1-2 years of protection for the rubber,plastic trim pieces, Gtechniques C4.
After all of that was done, I decided to revive the wheels by polishing them out and coating them with Poorboys wheel sealant.
Now that the car was finished, lets see what it looks like outside and in the sun.
Thanks for looking, For more write ups and articles, follow me on Facebook,Twitter, and Youtube.
Tru_Shine is offline   Reply With Quote
Old 02-10-2013, 11:02 AM   #2
teg97's Avatar
Default Re: 1985 Porsche 911 Carrera Gets restored by Tru Shine Detailing of Knoxville TN
perfect!
teg97 is offline   Reply With Quote
Old 02-10-2013, 12:23 PM   #3
Prudz_lude's Avatar
incredible, i love detail restores.
Prudz_lude is offline   Reply With Quote
Old 02-11-2013, 11:53 AM   #4
Mr. EG's Avatar
Great job.
Mr. EG is offline   Reply With Quote
Old 02-11-2013, 12:10 PM   #5
92teginsc's Avatar
92teginsc is offline   Reply With Quote
Old 02-14-2013, 05:15 PM   #6
SpeedoKing's Avatar
Amazing work, I always look forward to your threads, I have learned so much from reading them. A few questions though,
1. how did you remove and reapply the emblem on the back?
2. how did you paint the vents on the tailgate?
SpeedoKing is offline   Reply With Quote
Old 09-23-2013, 03:36 PM   #7
chet's Avatar
Great restorative detail, corrected all original paint is so much better than new paint in my opinion...
chet is offline   Reply With Quote
Old 09-30-2013, 05:38 AM   #8
Good lord dude, think they could miss the key hole a few more times? Yikes!
UGAVtech is offline   Reply With Quote
Old 10-09-2013, 07:00 PM   #9
UNKNOWN_MEMBER's Avatar
Quote:
i believe that's actually finger nails that caused those scratches.
UNKNOWN_MEMBER is offline   Reply With Quote
Old 12-23-2013, 07:43 AM   #10
Sweeet-nesss!
UtzChips is offline   Reply With Quote
Old 12-24-2013, 07:12 PM   #11
lilcraigford's Avatar
Great turn around! Original single stage paint you were working with right? How did the interior look on that car?
lilcraigford is offline   Reply With Quote
Old 12-26-2013, 07:15 AM   #12
So, the 'key' to a premium shine is in the polishing of the paint to correct the imperfections.
Consumer Report found none of the 19 wax products tested were good enough to be Rated excellent, with most showing signs of deterioration within a few weeks.
They also noted: Thanks to today's clear-coat finishes, our testing shows that even the best wax will probably not improve the shine on a new car. Regular washing is still the most important step to protecting your car's finish. But a coat of wax can add a layer of protection against tree sap, bird droppings, and other contaminants--at least for a while.
http://www.consumerreports.org/cro/c...ying-guide.htm
So, I guess I won't be spending $80.00 on an 8 oz jar of Zymol car wax.
Old 05-07-2014, 12:09 AM   #13
chet's Avatar
Correct, scratch free paint is what makes a car shine. Wax adds a bit of depth to the shine.
Old 09-15-2014, 11:52 AM   #14
Humphrizzle's Avatar
looks awesome! cant believe they put tiger paw tires on this car though.
Humphrizzle is offline   Reply With Quote
Old 09-27-2014, 10:52 AM   #15
RSZero1's Avatar
i hate to ask and you, and you can answer in PM if you want, but how much would I be looking to spend to do the same treatment, albeit my 20 year old honda.
I'd rather save the paint than repaint.
RSZero1 is offline   Reply With Quote
Old 12-23-2015, 05:05 AM   #16
guygeneric's Avatar
nice!
guygeneric is offline   Reply With Quote
Old 12-25-2015, 06:52 PM   #17
GDD's Resident Derp
You know your stuff. I want to take any car I love very much to you
W95civicEXcoupe is offline   Reply With Quote
Tru Shine Detailing Mercedes SL63 AMG rescue Tru_Shine Detailing 9 10-01-2012 10:52 PM
600hp 2010 Black Nissan GTR by Tru Shine Tru_Shine Detailing 8 08-06-2011 11:42 AM
Ferrari F430 Scuderia By Tru Shine and Unique Mobile Detailing Tru_Shine Detailing 13 07-27-2011 07:13 AM
FD RX7 gets De-Faded and De-Swirled Tru_Shine Detailing 8 04-07-2011 10:57 AM
*Warning! No diving!* paint appears very deep! *No life guard on Duty* Tru_Shine Detailing 35 11-09-2010 10:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
