Race car part out !!
***asking 7500.00***
(this does not include suspension/wheels/drivetrain / NO extras, besides whats listed below)
will entertain trades for "street car" type vehicles. let me know what you have
__________________________________________________ ________
1992 honda civic si racecar chassis
* 10pt chromoly cage with parachute mount/wheelie bar hookups
* Custom aluminum dash, door panels and interior panels
* chromoly wheelie bar with wheeleze wheels
* stroud window net
* omp race seat
* FAL lexan windows (race kit) * Lexan sunroof *
* MB Products fiberglass doors with chromoly frames and lexan window with stainless allenhead bolts/nylock nuts
* Tube front end with midplate & chromoly timing belt side mount
* clearanced for 28" tires
* Acura sundance gold pearl paintjob
* entire chassis was sand/bead/media blasted before paint
* Carbon fiber front nose
* spare tire well is cut out, with flat aluminum panel covering
__________________________________________________ _______________
__________________________________________________ ________________________
milspec harness, built by me, with tefzel wire/raychem dr-25, deutsch connectors etc. 1200.00
the harness was originally used with an aem box, it now is used on a motec m48. so it has the motec ecu connector on it along with the serial port.
this is the harness before i added in the extra 4 injectors (it now has 12injectors )
__________________________________________________ ______________________________
Front mount B series T4(split housing) turbo manifold
- 304 stainless, tig welded by Jm Fabrications
- tial 44mm wastegate flanges[/B]
- has extra mount for support
- 800.00 + shipping
Garrett Gt4202R Turbo
- 74mm
-1.10 a/r exhuast housing
- ball bearing
-water cooled
- includes inlet restricter flange
- includes compressor and turbine discharge flange and v band clamps
- does not include air fitting
1500.00 + shipping
JM-Fabrications / Spearco water to air intercooler
* 4-inch v band inlet and outlet
* -12AN water outlet fittings
* -12AN drain
550.00 Shipped
All associated lines/fittings
* 12an fittings on tank & intercooler
* 3/4 shut off valve on tank for drain
* hose is 3/4 inch
85.00 shipped
Hydraflow clamps 225.00 each
* fits 4inch tube
* i have 4 clamps
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
*obd2b to obd2a jumper harness
150.00
______________________________________________ -
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
Oil Catch can
80 shipped
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
