Parting out my sfwd 92 EG hatch Full-race, AEM, JG, etc...
All prices are negotiable and do not include shipping costs. Low ball me if you want, I may be in a good mood and let you have it. Please PM me with any questions. I am just going to list what is for sale and some pics that I have. Everything is still on the car and car is in perfect running condition.
Pics of the car can be found here: http://speedeg.com/hatchpics1405/
Bottom end
SOLD fully assembled Golden Eagle Sleeved B18c 84.5mm block refreshed last year and has 150 miles on it. leakdown was performed last month after last race and was less than 5% across the board. Block includes the following:
CP 84.5mm 9:1 pistons
JE X-rings
Pauter Rods
ACL Bearings
ITR oil pump
Bottom end gasket seals
ITR water pump
Micro polished GSR crank
cnc bore and hone
Balanced and blueprint
Cometic MLS Head Gasket
OEM ITR Oil Cooler
Just added
My spare block and bottom end parts for it
DART B Series 85mm Block. Needs a fresh hone SOLD
Brand New Wiseco 9:1 coated 85mm pistons SOLD
Brand New Manley Turbo Tuff GSR Rods SOLD
Brand New ITR oil pump SOLD
Brand New ITR Water Pump SOLD
New Golden Eagle Mfg 85mm head gasket SOLD
Mint gsr crank $125
2 sets of Clevite 77 Standard GSR/ITR Bearing Set $90 each
New Golden Eagle mfg 84.5mm head gasket $90
New Cometic .36 85mm head gasket $90
New Cometic .36 84mm head gasket $90
Golden Eagle Mfg Oil Sandwich adapter SOLD
Golden Eagle Mfg Vacuum Block SOLD
Endyn Catch Can with lines and hoses SOLD
Engine Head etc
$1600 2001 B18C5 Head (bought brand new) has about 300 miles fully assembled includes:
3 angle valve job
REV Nitride coated valves .5mm over
REV Valve Sprins
REV Titanium Retainers
Head Quench pads ported
Chambers port matched to 84mm
AEBS Head studs
STR Titanium Cam seal
SOLD!Red USDM ITR Valve Cover Stainless Steel -10AN valve cover lines and fittings for catch can installed on front
Cusco Catch Can for Valve cover venting
Mazworx Turbo Cams V1 40 miles on cams made 587 whp @22 psi - $450
JDM CTR CAMS 5 miles on them with stock cam gears - SOLD
EdelBrock VictorX Intake Manifold for b16/itr -SOLD
USDM ITR Throttle Body - SOLD
Fluidampr sfi crank pulley SOLD
Suspension
Omni Power Full Drag Coilovers for ITR- SOLD
Buck02 Limiting straps welded onto forks $150
Full-Race Traction Bars of EG and DC - SOLD
Hasport Extreme Race urethane engine mounts for b series eg/dc - $300
JDM GSR Shifter- SOLD
Black Sparco Sprint Seat Sparco Rails/ Slider for 92-95 EG & 94-01 Integra, comes with RCI 5 point harness red - $300 OBO
JDM ITR Non SRS Steering Wheel- SOLD
JDM ITR red Stitch Shift Boot- SOLD
Electronics and engine management
AEM EMS 30-1040 jumpered for T1 hall sensor COP system $900 OBO
Tony1 hall sensor cam gear kit with AEM C2DI Twin Fire ignition andHonda CBR 600RR Coil pack (3 sets of coils), new Denso Iridium IK27 Spark plugs (heat range 9) all wired and ready to go has about 30 miles, 15 dyno passes, 5 1320 passes - $750
AEM 5 bar Map sensor SOLD
FJO Injector Driver (for 1000cc and up injectors)- SOLD
PLX M300 WideBand Controller with sensor- SOLD
Greddy 60mm Electronic White Face EGT Memory Guage $120
Greddy 60mm Electronic White Face Oil Pressure Memory Guage $120
Greddy 60mm Electronic White Face Fuel Pressure Memory Guage $120
Greddy 60mm Electronic White Face Boost Memory Guage $120
Apex-I EL 5” Memory Tachometer with Shift Lite $100
NRG Earth Grounding kit (was on car but taken off) $50
Greddy Profec B Spec II Boost controller - SOLD
Fueling
Precision Turbo 1000cc injectors SOLD
USDM OEM ITR Throttle body with all sensors SOLD
Custom -8an dummy pump sump system with Stainless Steel -8an fuel lines from back of car to engine bay and Bosch 044 External pump (700HP) and Aeromotive 10 micron inline filter, Bosch 30 AMP Fuel relay system, Mounting brackets - SOLD
Summit liquid filled fuel pressure guage SOLD
AEM Fuel Rail (Blue) - SOLD
STR Eliminator Fuel Rail with stock regulator- $45
Aeromotive Fuel Pressure Regulator (red) with b&m fuel pressure guage -SOLD
AEM Fuel Filter - SOLD
Bosch 044 pump (new) - SOLD
Cooling
Mugen Race Thermostat SOLD
Mugen Thermostat switch SOLD
PWR Radiator with B18Bturbo fan SOLD
Samco Blue Silicone Radiator Hoses $70
Drivetrain
Exedy Multi Plate Clutch MH022SR 300 miles and still in great shape SOLD
Mazworx b series scatter shield painted red better fitment than others SOLDGator Stage 3 (650 WHP) axles with modified hubs (36mm) 4 lug spindles included $500
97 Spec JDM ITR Tranny 4.4fd with quaife lsd installed no grinds etc $1800 obo
Turbo goodies
Full-Race SFWD ProAm T4 Stainless Steel Top mount Manifold and Full-Race 3" SFWD ProAm Stainless Steel Vband disconnect, manifold and dp- SOLD
Precision Turbo PT67R DBB SOLD
Garrett GT35R DBB Turbo with oil feed and return lines SOLD
Tial 44mm VBand Wastegate 1 bar spring- SOLD
Tial 50mm BOV $150
Precision Turbo 30x10x3.5 AS1026 Intercooler (750 HP) SOLD
used Greddy Type 24 intercooler (575hp) $250
NEW custom 31x12x3 intercooler (800hp) $175
New AFI 4" Aluminum full Exhaust for EK/EG vbands and Burns Muffler weighs 12lbs- $750
Chassis/shell: SOLD!SOLD!SOLD!!
Clean title
1992 Honda Civic CX 130k on chasis
Custom 2 tone Nissan canteen Green paint and GM midnight black (roof)
Invidia Carbon fiber OEM hood
Invidia Carbon Fiber OEM Trunk
JDM **** Carbon Fiber Mirrors
JDM **** Carbon Fiber DuckBill
Rear Bumper Diffuser Modification
Home Depot front lip
99 JDM ITR 5 Lug Conversion (36mm hubs)
Gator stage 3 axles
16" GM JDM ITR Rims and tires
Full-Race 6 point Chromoly Roll Cage
Dash
stock cluster
heater controls
headlights
oem seatbelts
oem seats
oem shift boot
oem airbag steering wheel
Extras that will be included
oem hood (red)
oem rear hatch (red)
oem duckbill
certifit passenger fender (unpainted)
certifit [B]bumper (unpainted and cut for intercooler and piping)
Modified by 00ITR #543 at 9:06 AM 12/4/2006
Bottom end
JE X-rings
Pauter Rods
ACL Bearings
ITR oil pump
ITR water pump
cnc bore and hone
OEM ITR Oil Cooler
Just added
Mint gsr crank $125
Engine Head etc
3 angle valve job
REV Valve Sprins
AEBS Head studs
Suspension
Fueling
Cooling
Drivetrain
Turbo goodies
Tial 50mm BOV $150
Clean title
Gator stage 3 axles
Dash
stock cluster
heater controls
headlights
oem seatbelts
oem seats
oem shift boot
oem hood (red)
oem duckbill
Re: Parting out my sfwd 92 EG hatch Full-race, AEM, JG, etc... (Day-DayC)
All pms replied too. Got a lot of emails and pms, everything is first come first serve!!
Shooting Star
hey just letting you know i was still interested...just wondering did everything go through with the pt67r...its in the t4 housing as well right...if it doesnt sell id like to get that as well as the car. let me know
Re: (FRANK_WHITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANK_WHITE »</TD></TR><TR><TD CLASS="quote">bump for you debating on that short block or a vacation lol</TD></TR></TABLE>
Short block!!
Short block!!
Re: Parting out my sfwd 92 EG hatch Full-race, AEM, JG, etc... (00ITR #543)
bump for some quality parts... would you mind sharing how much you sold the FJO for? you can me pm me, im curious. thanks
