new d16 eagle rods, 2 used eagle rods, vitaras, je pistons
well a lot of unexpected thing are going on with my build so now im have a bunch of rods and pistons, and really need to get them moving
started off with me buying 3 eagle rods with 3 vitaras, then bought another rod with a vitara but when i got it it was an older style rod.
which then lead me to think of buying a 4th matching rod from eagle but instead found a set of brand new eagle rods an supposeably cp pistons on ebay. paid for them buy it now, waited a few days seller never responded, i checked his ebay page, the seller canceled his ebay account.
i contact my credit card, ebay and paypal on friday the week of when payment was sent, they then are in the process of a credit back takes about 10 business day, mean time i find a local guy saying he has eagle rods and je pistons, i go check them out, they are not eagle rods, but are cunningham rods with je oversized pistons about 8.5 compression.. i never heard of cunningham rods so i pass on them, i do a little research, they are known, lisa kubo had used this same brand on one of her 9 sec civics. so i say okay, they should be able to handle my power goal. so i go back pick them up.
2 days( friday) later the pistons and rods i bought on ebay arrives at my door step. im like ***. i open them well sht. im sht out of luck again. they are brand new eagle rods, but the pistons are not cp. they are some aftermarket factory pistons. i call paypal and i say that it is not as described. they say the only way i can get my money back is if i sent it back to the guy, with a confirmation number, and when they see that it arrived at his door step they will withdraw from the guy and refund me back. im like *** that. i have to send the rods and pistons back and then they will refund me. and there was no guarentee they can get my money back.
so now i have a bunch of stuff and need to sell
contact:
619 2451445
what i would like to do is sell as a package if possible
4 new rods with used vitaras---320 add 10 if you want bearings
4 new rods with used vitaras or je pistons 320 add 10 if you want bearings
4 new rods with 2 used rods---400
or ask for possible combo
so what i have are :
4 d16 standard length eagle rods. newest model, they have the eagle etched on the rods eagle 200 arp rod bolt with arp lube---300
NEW ONES ARE THE 4 BOTTOM ONES
2 used standard eagle rods, with eagle arp 2000 rod bolts----70 each
THE 2 UPPER ONES
1 used older style eagle rod, with arp 8740 rod bolts---60
4 used 75mm vitara pistons with used rings. one piston has some scuff marks---40
some aftermarket y8 75mm stock compression pistons with new rings---80, cuz i might use the rings
new after market rod bearings----20
contact:
619 2451445
THE 2 UPPER ONES
DixielandImports Please
Re: new d16 eagle rods, 2 used eagle rods, vitaras, je pistons
If you still have the set of 4 new rods I will pick them up as soon as I sell my I-beams and vitaras.
iownahatchback
06-01-2010 11:00 AM
