JRSC B16/B18C5 zero miles on rebuild/s-port +crv crank pulley, avail w/B16swap
I pulled my set-up right after I installed the S/C due to a wire harness problem and now that it is on the floor i would like to sell it and try something different. I bought the jrsc used from a HT member and when I recieved it I didn't like the condition it was in so after much research (endyn, moss, ect..) I went with http://www.pse.us for the rebuild work. The quality of bearings and the amount of experience Ed has could not be matched by the others. While it was there Ed S-Ported the blower to maximize the airflow through the unit, manfold had a hairline crack and was then tig welded and surface of manifold was planned for a perfect fit to the head. I spent over $900 to have the work completed and have never drove on it. I bolted it to the head and it went into the car for a couple days until a wire problem forced the engine removal. This unit will run cooler, outboost, outlast and outperform any other jrsc (even a new one out of the box). Complete swap available...reciept avail for proof of work done.
JRSC (w/ all part that I have..new belts, bolts, ect) and CRV crank pulley $2000
JRSC as it sits in the pics...including,
B16a
Si cable trans
CM stg 2 clutch
CM lightweight flywheel
HP racing header
HCP EF mounts
OBD 1 gsr dist (new)
hondata intake gasket
DSM 450 injectors
short ram intake
$3900 for everything. trades considered??
B16a
Si cable trans
CM stg 2 clutch
HP racing header
HCP EF mounts
DSM 450 injectors
short ram intake
Re: JRSC B16/B18C5 zero miles on rebuild/s-port +crv crank pulley, avail w/B16swap (Don'tNeedV8)
I have a friend I'll talk to about it when I get home. " at the father-in-laws now"
I can't get the pics to work????? And where in IL are you from, can pick up
joepark2001
05-09-2008 12:21 PM
NVMYSi
01-06-2005 11:08 AM
