FS/FT:Going K,600whp turbo part out,Precision 6262,Inline Pro,Neptune RTP,Aem,Etc
David Heeter
Valdosta, Ga 31605
229-251-2676 text or call
The car was put together in Dec/Jan., tuned by RLZ engineering in March, made 611/390 on 25.5lbs on e85. All components are from a GSR and have less than 3500miles. Everything is obo. Text or call for quickest response, 229-251-2676
Turbo Stuff
Inline pro SS mani, Tapped for T3 or T4, comes with 2 bolt fange for wastegate and used 3 inch 4 bolt downpipe $365 shipped
31 x 4 Inter cooler with 2.5 inch Inter cooler Piping, has HKS Bov Flange SOLD
3 inch,4 bolt used passenger side downpipe $60 shipped
New, 3 inch 4 bolt downpipes, passensger side style,(works with logs and ramhorns, $110 shipped
New, 2.5 inch passenger side downpipe, no flanges, brand new $75 shipped
Ignition system - $475 shipped
AEM Twin Fire ignition box, removes factory ignitor which tends to fail on high power aps, $290 shipped
GSR Distributor with MSD Cap and Rotor, MSD SS Coil $150 shipped
MSD 8.5mm Wires $60 shipped
Motor 84.5mm Golden Eagle sleeved Block,Damaged
The Bad, Dropped a valve that took out number one. Local shop said it can be bored to 86mm but I recommended sending it into Golden eagle or another sleeving company (Darton, ERL, etc) to get re-sleeved
The Good, GSR Block (saves core charge), GSR Crank, Main Caps with ARP studs, Girdle with ARP Studs, GE oil squirters, Crower H beam rods. Send it in and get it resleeved, buy a set of pistons and bearings and you have a new built bottom end. $600 obo you pick up or pay to ship
Will sell Block with Crank, caps, girdle, squirters and APR studs for $400 picked up
Crower GSR H beams rods,used for 3500 miles for $200 shipped
Misc items
EK Fog Lit kit complete and new $35 shipped
ITR Throttle Cable and bracket $20 shipped
92-95 Civic 3 gauge pillar pod $35 shipped
Blox b series cam seal, new $20 shipped
GSR Cams $60 pending
GSR repainted wrinkle black Valve cover $55 shipped
Stock/Swap parts(b-series)
B series, GSR Alternator (1 month old) $70 shipped
92-95 obd 1 Vtec Engine Harness $110 shipped
B-series Vtec solenoid $25 shipped
B- Series GSR IACV $25 Shipped
Also have every sensor or B-series swap part available from the long block, Pm me with a request
SOLD
Precision Billet 6262, Ported .70 S cover and .82 4 bolt exhaust, warranty until Dec. SOLD,SHIPPED
SC4 B16 Transmission with LS 5th , no grinds, popouts, shifts like butter. SOLD and picked up
Precision 46mm V-band Wastegate, 1.5, 6, 9, 14, 18lb springs SOLD, SHIPPED
Endyne/Moroso catch can setup, includes block fittings, Sold and Picked up
Avid Billet B-series Motor mounts, 3 post driver side SOLD and SHIPPED
Edelbrock GSR Intake, Painted Black includes hondata gasket SOLD and Shipped
Comp Stage 5 clutch and resurfaced GSR Flywheel,1500 miles SOLD and Shipped
Ge Sandwich plate with feed and return line Sold and Shipped
HKS Super Sequential Bov,Black edition Sold and Shipped
Moroso B-series oil pan. Sold and Shipped
Mac Boost by gear solenoid Sold and Shipped
ARP Head Studs SOLD and SHIPPED
Omni Dual Springs and Titanium Retainers SOLD and shipped
B- Series Trannmision Torque mount Bracket SOLD
B- Series Transmission/motor T- Bracket SOLD
Neptune RTP Demon inside xenocron modded P28 with pwm/boost by gear, will transfer license to new owner SOLD
ID 1000 Injectors, 2 months old, comes with obd 1 plug n play clips SOLD
Aem B-series Fuel Rail, Black SOLD
Omni 4 bar map sensor SOLD
Blox Billet 70mm TB, includes blox tps and hondata gasket SOLD
Valdosta, Ga 31605
Turbo Stuff
Misc items
SOLD
Re: FS/FT:Going K,600whp turbo part out,Precision 6262,Inline Pro,Neptune RTP,Aem,Etc
These are all the pics I have currently but everything is pulled and i will get new pics up tomorrow
Dyno vid and the dyno sheet (Torque on left and hp on right, setup backwards)
Turbo
Engine bay pic
Front mount
Like I said above everything is pulled and I will get new pics up of everything tomorrow
Thanks for looking
Turbo
Engine bay pic
Front mount
Thanks for looking
got a ton of pics on my phone text me for pics. 229-251-2676
Once I get all them sorted and uploaded to photobucket I will post a link
Added items
GSR Cams
ARP Head Studs
B series, GSR IACV
GSR Cams
ARP Head Studs
B series, GSR IACV
Bump for Neptune RTP Demon and Inline pro manifold, Lets get these gone
can u ship this to India via USPS? shipping costs please? can do paypal.
Added items
B series, GSR IACV $25 Shipped
B series, GSR Alternator (1 month old) $75 shipped
Omni 4 bar map sensor (plug n play) $75 shipped
B series Vtec solenoid $25 shipped
ID 1000 B series injectors with obd1 plug n play clips $415 shipped firm
Blox b series cam seal $20 shipped
92-95 obd 1 Civic Harness $110 shipped
Uploaded some new pics to my photobucket check them out.
http://s3.photobucket.com/albums/y73/heetstroke/
Neptune, rail, and map sensor sold
Lets get this inline pro moved fellas
