FS: B Series Vortech Supercharger - High Output - Powdercoated
SOLD SOLD SOLD
Edit: Installed the kit Pic! No i have not had it tuned, this car is going to be an e85 only car which means no tuning or runtime until spring. Kit will be removed from the car once a serious buyer is found.
Re: FS: B Series Vortech Supercharger - High Output - Powdercoated
It will fit for sure on a b16/b18c5/b18c1. What is the deck height difference between the engines i listed and your b20/ls? The main bracket was t slotted on the block so id imagine it should fit any b series engine at this point.
I believe it should fit fine how-ever the power cooler may need a small elbow for your intake manifold. I believe the power cooler was slightly different between the gsr and the type R/b16 heads.
Ill take some installed/mock up pic's this weekend.
Will take some this weekend as soon as i get a chance, just going to put it in place to snap the pic's because im pulling out the engine as well to start a whole new build.
This kit retains power steering and air conditioning if needed. Also im selling a perfect header for this set-up in another thread that was converted to a 3" exit for b series. Fits perfect with this supercharger and should make some serious sleeper power.
