Darton Sleeved B18C1 Block With Crank
Darton Sleeved B18C1 Block With Crank and Eagle rods $950
I am selling my Darton MID sleeved B18C1 GSR block, crank, and Eagle rods. All you will need is a set of pistons and you will have a complete sleeved short block. The bore is currently at 84mm but will need to go to 84.5 due to minor dings. The sleeves are o-ringed. The block also comes with the crank installed, crank pulley, water pump, tensioner, windage tray, oil pickup, and oil pan. The oil pan already has the oil return fitting welded in. The price is $950 obo. It is located in north east PA. Please call/text me with questions or if you would like to see it at 570-417-2890.
Re: Darton Sleeved B18C1 Block With Crank
A portion of the valve broke and caused small dents in the cylinder. The piston care out easily. Boring to 84.5 should definitley clean it up. Thanks.
Are the "dings" in all of the cylinders or just one? Could be easier to replace a sleeve and have it honed at 84mm for the people who are worried about going 84.5mm.
