Classic Hondas All Pre-1988 Hondas.
Timing belt tensioner
Old 06-07-2014, 04:42 PM
ke7joi's Avatar
Default Timing belt tensioner
Can someone tell me if the timing belt tensioner bolt on a 1986 ew4 motor is special the head is striped and I need to replace the bolt. To replace the timing belt?
Old 06-07-2014, 06:08 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
Default Re: Timing belt tensioner
is it the pivot bolt or the tension bolt? both are metric shoulder type bolts, I doubt you'll find them anywhere, try the yard most Hondas around the same era use similar bolts, they are most likely the same
Old 07-12-2014, 10:38 PM
rrambo4u's Avatar
It's the bolt that goes in the middle of the tensioner. So it's the tensioner bolt. The pivot bolt is fine. I had to sand and file the bolt we have just to get it to be able to be tightened up.
Old 07-13-2014, 06:37 PM
ej1995's Avatar
Should be able to get something that would work from the local hardware store or go to somewhere like Fastenal. Sometimes you can order the bolts from bkhondaparts.com, i would look it up for you but im too lazy at the moment.
Old 07-16-2014, 07:51 AM
rrambo4u's Avatar
Hey thanks for the info, I have been on that website before. Yes to to avoid confusion ke7joi and I are talking about the same car.
WaryDriver
27
10-07-2015 08:42 PM
MC Slide Hammer
03-23-2011 02:25 PM
b17gsr
02-11-2003 07:46 PM
3rdGteg
04-23-2002 02:48 PM
3rdGteg
01-28-2002 02:54 PM
Quick Reply: Timing belt tensioner
