86 Honda Accord - Honda-Tech
86 Honda Accord
Old 12-20-2009, 08:17 PM   #1
Default 86 Honda Accord
I have an 86 Honda Accord (Carburated-Automatic). I start the car by hitting the gas once and then start. It goes to 2200 RPM's and then after a moment or two I kick it down to 1500 where I put it into Drive and go. Is there an adjustment I can make that will adjust both above RPM's down as I am afraid
I am going to hurt the trans by putting it into gear at 1500.
Thank you very much for your help!
FrankBHonda is offline   Reply With Quote
Old 12-20-2009, 09:41 PM   #2
2DrSE-i's Avatar
Default Re: 86 Honda Accord
No experience at all with the carbed accords. 3geez.com is your friend!!
2DrSE-i is offline   Reply With Quote
Old 12-21-2009, 12:59 AM   #3
2ndGenGuy's Avatar
Your car is running how it should. It is supposed to run about 1500RPM until the engine warms up a bit. It won't hurt it to kick it into drive like that. It does eventually settle down to ~750RPM or so, doesn't it after it warms up?
2ndGenGuy is offline   Reply With Quote
Old 12-21-2009, 08:58 AM   #4
Thank you for the response.
Yes it does settle down after driving for a few minutes to a lower very smooth RPM around 750. So it doesnt hurt the trans to place in gear at the high RPM?.
This is a very nice shape 86 Honda we just bought for my daughter and it runs and looks great. It looks as though it has a pretty new trans.
Old 12-21-2009, 10:30 AM   #5
2ndGenGuy's Avatar
Nope, sounds like it's running great. Just as it should! No worries about putting it in gear at high idle. It was designed to do it.
Old 12-21-2009, 02:20 PM   #6
Thanks. Are there PCV valves on these?
Old 12-21-2009, 03:49 PM   #7
2ndGenGuy's Avatar
Yes, I believe on the 3rd gen it's on the intake manifold. If I remember right (been a while since I worked on a 3rd gen) it's in between runners 2 and 3.
Old 01-06-2010, 06:13 PM   #8
It might help out if you let it run for about 5 minutes before you go. I always let my car run for a small amount of time before I go when it is cold, but it will not hurt it to just start it and go.
rxbahamut is offline   Reply With Quote
revs problem 94 Accord Ex Splitf22 Honda Accord (1990 - 2002) 1 03-30-2010 07:25 PM
weird idle throttle problem on Dc1 1.6 integra soch lezor Acura Integra 2 04-04-2009 10:00 PM
car starts but whont rev high. TURBO+GSR+CRX=? Honda Civic / Del Sol (1992 - 2000) 29 02-02-2009 11:18 PM
86 carb. accord stalling under 1500rpm warchild69 Honda Accord (1990 - 2002) 2 01-25-2004 10:18 AM
Why is my b18b sticking at 1,500 rpm when sitting still? tremor86 Acura Integra 3 08-24-2002 09:23 PM
Tags
1986, 3geez, 81, 86, 86hoda, 86honda, accoardcom, accord, high, honda, idle, motor, pcv, support, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
