Classic Hondas All Pre-1988 Hondas.
82 honda civic with EK1
Old 11-13-2009, 05:19 PM
sickmojave's Avatar
Default 82 honda civic with EK1
I just bought a 1982 honda civic 1300. I am trying to find out if this car came from the factory with a ek1 motor .the guy I bought it from said it was the stock motor but he was the third owner. i think somewhere down the line it was changed. the numbers on the motor are EK1 5530054. the best I can tell is thats a 1.8 and the civic didn't have that engine as an option in 82. I really need to know more about this motor like what to set the valve lash, spark plug gap and I would like to change the timing belt.
any help would be great.
Thanks, James
Old 11-13-2009, 10:18 PM
redr2's Avatar
Default Re: 82 honda civic with EK1
The motor is not stock. Its out of a Prelude or Accord.
timing belt adjustment/pivot belts - torque to 31 ft lb.
cam gear - 22 ft lb.
crank gear - 83 ft lb.
valves:
intake and aux:
.12-.17 mm clearance
exhaust:
.25 - .30 mm
All this from a Factory Honda Service manual.
Old 11-13-2009, 10:22 PM
redr2's Avatar
ps - plug gap is 1.0 to 1.1 mm
Old 11-14-2009, 03:30 AM
sickmojave's Avatar
Thank you for the info. I did order a manual for this car but it didn't cover this engine. I guess I will have to order 1 for the accord
Old 11-14-2009, 05:13 PM
sickmojave's Avatar
I keep finding more about this car. the shifter *** says 1-4 but I found 5th gear today.
Old 11-15-2009, 04:19 AM
smithenhiven's Avatar
I'll have to check, but I think I have a book for the first gen accord if you didn't already order one otherwise.
Old 11-15-2009, 05:43 AM
Stretch7's Avatar
This would be the first gen Accord/Prelude. 1976-1978 had a 1.7L EM-1 engine. More specifically on the Accord it would only be the Accord engine from 1979 to 1983. If you want/need a specific year of Accord/Prelude:
1979 - 1000001 and up
1980 - 2000001 and up
1981 - 3000001 and up
1982 - 4000001 and up
1983 - 5000001 and up
If it qualifies for the 1983 year, it would only be an Accord engine. I have the EK-1 from a 79 model Accord in mine.
Depending on the engine that came in the car from the factory, it may have had a 4 speed in it. The 1300s came with a 4 speed tranny OR a 5 speed. The 1500s only came with 5 speeds. Both came with automatics. This is all if your car is an HB.
Check your chassis code.
SL-431 is a 1300 4 speed.
SL-532 is a 1300 5 speed.
SR-332 is a 1500 automatic.
SR-532 is a 1500 5 speed
SR-533 is a 1500 5 speed and the model would be GL
Hope that helps the break down a little more in depth for you.
Old 11-16-2009, 08:21 AM
sickmojave's Avatar
Thanks guys.
I now know that I have an 82 civic HB with a 83 accord engine. my guess would be that it has the accord 5 speed sence the vin # says it came with the 4 speed.
Old 11-16-2009, 08:23 AM
Stretch7's Avatar
Glad I could help. Well, if you got that info from the info I posted.
kunle
Transmission & Drivetrain
08-19-2017 01:48 AM
Targeteer2
14
09-07-2013 05:21 PM
TURBO+GSR+CRX=?
02-01-2009 10:45 PM
davken1102
09-21-2008 06:26 PM
Quick Reply: 82 honda civic with EK1
