1988 civic dx fuel pump issues - Honda-Tech
Old 06-20-2010, 07:56 PM   #1
Default 1988 civic dx fuel pump issues
I have a 1988 civic dx 4 door sedan, 1.5L, I recently have been having trouble with the fuel pump? I figured it was bad as I was getting no fuel and the car would'nt start, will run with Gummout!,. I went ahead and replaced it(the fuel pump),... it still does not seem to pump fuel! I checked the old one with 12 volts and it works! Rats! 201$ out the window! The sevice manual says to check the main relay, located under dash, next to the fuse panel. There is a series of connecting terminals together and providing 12 volts to other terminals in a peticular sequence, it check out good, I'm only getting about 6 volts at the fuel pump/sending unit plug (access under rear seat)? Could my ECU be bad? I'm scratching my head on this one. any advise would be greatly apreciated!!
Thanks,
rzecca is offline   Reply With Quote
Old 06-21-2010, 07:11 PM   #2
Gabe87CRX's Avatar
Default Re: 1988 civic dx fuel pump issues
Check the fuse in the fuse box labeled ALTERNATOR / SOLENOID, just had this problem...
Gabe87CRX is offline   Reply With Quote
Fuse Size / Electrical query regarding Fuel Pump SupaMonkey Honda Civic / Del Sol (1992 - 2000) 11 04-12-2016 07:44 AM
89 Civic Si fuel pump not working! Steenracing Honda CRX / EF Civic (1988 - 1991) 11 10-07-2014 09:55 AM
Clicking starter relay. no start. 0 volts at starter terminal Schultzie Tech / Misc 4 01-23-2013 10:46 PM
Starter won't crank, Remote Wire only has 3 volts Nisif Honda CRX / EF Civic (1988 - 1991) 6 05-19-2008 11:52 PM
Fuel pump voltage problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! efking1985 Honda CRX / EF Civic (1988 - 1991) 4 02-17-2007 09:56 AM
Tags
1988, 90, accord, civic, common, dx, filter, fuel, fuse, honda, located, problems, pump, srx, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
