Classic Hondas All Pre-1988 Hondas.
1985 honda crx dx ignition coil
Old 04-28-2010, 02:48 PM
fastlimegreencivic's Avatar
Default 1985 honda crx dx ignition coil
So ive been trying to get my crx running for a few months now. I have replaced the distributor cap, fuel pump, spark plugs, and last the ignition coil. We tested the old ignition coil and theres some spark, but car won't start. I bought the new one and the new has no spark at all. I have someone helping me out with this issue. In order for the ignition coil to spark and the car to turn over the ignition coil needs to be firing at 1.06-1.24 ohms? I am confused with this and need some help thanks.
Old 04-28-2010, 05:05 PM
chevy5412's Avatar
Icon6 Re: 1985 honda crx dx ignition coil
check the ballest ristor on the side of the coil check the voltage going to the coil low voltage will cause a weak spark and if all that is good check your compression on your cylanders low compression like around 80 psi it will not run it should be at 160 to 180 psi
Old 04-28-2010, 05:27 PM
Gabe87CRX's Avatar
Default Re: 1985 honda crx dx ignition coil
Make sure fuel is getting through that filter... you should have replaced that with the pump.
Old 04-28-2010, 07:40 PM
I ll check it out thanks a lot
Old 04-28-2010, 08:12 PM
oh yeah the filter was replaced as well
Old 04-29-2010, 06:19 AM
gimpalot's Avatar
You may want to make sure that your camshaft is actually turning.
If the cam doesn't spin, you get no spark....
I have actually seen a couple of instances where the key way on the cam gear sheared off and the gear was just spinning on the shaft.
Old 05-05-2010, 05:30 PM
Richweir1's Avatar
You need to stop buying parts, start at point 1 is the distributor and cam spining? Pull the cap off and have someone crank the engine. If so use a timing light on all spack plug wires to see if you get spark anywhere.
3rd if everything is moving, and you have no spark, then you need to start over again with the eletrical side. check your main fuse, resistors and wiring for damage or unhooked. if you find nothing then email me and we can go from there. ilwacoauto@yahoo.com
B18ceed
03-20-2006 10:57 PM
gottagofaster
10-21-2005 11:58 PM
shreker
06-27-2005 07:54 PM
turbo Si
10-22-2002 03:32 AM
phildeez
03-15-2002 07:22 PM
Quick Reply: 1985 honda crx dx ignition coil
