Wiring alarm to clock 12v constant power
Old 09-15-2014, 07:20 PM
mfreeman's Avatar
Default Wiring alarm to clock 12v constant power
I'm in the process of doing a stealth alarm install on a 1995 Civic and am looking to hide the power connection completely rather than splicing into the white wire on the fusebox or using one of the empty option ports.
Would soldering the alarm to the clock's 12v constant power be feasible? Are there any other constant 12v wires I could use? The dash is completely removed from the car so I have access to everything.
The stereo is 12v accessory power and would not work for this if I'm understanding things correctly, right?
Old 09-15-2014, 07:53 PM
Nbboy7's Avatar
Default Re: Wiring alarm to clock 12v constant power
I wouldn't do that. If you want it stealth get the power from the back of the fuse box.
Old 09-16-2014, 04:23 PM
mfreeman's Avatar
Pulled down the fuse box and soldered it in behind there, can't see a thing thx.
Old 09-30-2014, 01:00 PM
NerfGunner420's Avatar
lol you want a stealth install get a back up battery. it won't matter once they pop that hood and disconnect that battery. what you are doing is semi stealth alarm install. a full stealth alarm install for me is prox sensor so it warns if you stand by the car and goes off if you stand by it for too long. tilt sensor. window sensor. and dual shock sensor with 2 way alarm. cost me $300+ said and done
H22AFerio
02-25-2011 12:13 PM
jiggatone
Lighting
01-27-2008 07:47 AM
frog169
Audio / Security / Video
09-16-2006 11:19 PM
sauceja
07-09-2005 09:53 AM
puffxy
08-07-2003 02:20 PM
Quick Reply: Wiring alarm to clock 12v constant power
