What causes a relay to buzz? The starter cut relay in perticular. - Honda-Tech
Old 01-12-2002, 04:26 PM   #1
Default What causes a relay to buzz? The starter cut relay in perticular.
When I start my car and the car is completely cold and its cold outside, I get this loud buzzing coming from inside my dash board. The buzzing lasts from anywhere from 1 second to 15 seconds. Once it goes away everything else seems fine.
I first noticed this on the first real cold morning after I got my alarm installed. Maybe a week or two afterwards.
Well I finally found out that its coming from my starter cut relay. It only happens sometimes and when the clutch is in (clutch switch on), as soon as I let out the clutch, it goes off (no power to relay). Also, it never happens again. Only when starting.
I tried a new relay, and it still does it. So the relay's not the problem. Does anyone have any ideas?
JM Performance is offline   Reply With Quote
Old 01-12-2002, 05:02 PM   #2
Default Re: What causes a relay to buzz? The starter cut relay in perticular. (Teken)
Teken, thanks for you help, but this could still be the problem w/ the stock relay??
Old 01-13-2002, 08:04 PM   #3
What I'm saying is that this problem occuring in the stock starter cut relay. I dont think the relay is the problem, but rather somethign else that is causeing the relay to do this.
I'm not sure if this is related or not, but since I installed my TT (not sure if its a coincidence or caused by it), sometimes, mostly when its cold, my alarm clicks (like a relay) when the clutch goes in, then back out. Again, this is from the clutch switch.
Could there be a problem with my clutch switch? Or maybe a pinched wire, or a short or something??? I tried following the wires by the clutch switch but its tight as hell back there. I guess I can take out the underdash fuse box to get a better look......
Old 01-13-2002, 08:46 PM   #4
Ok, tried your test. And the car would NOT start. So I guess thats good. I think I'm gunna take out the fuse box and try to see whats going on back there better.
On an unrelated note (I think it is), is there supposed to be a brown 4 socket connector not connected to anything taped up behind the fuse box? I saw it back there and it caught me by surprise.
Thanks,
Matt
Old 01-15-2002, 07:32 PM   #5
Default Re: What causes a relay to buzz? The starter cut relay in perticular. (00SilverLS)
Teken....more help please? What does that test tell me?
Old 01-16-2002, 12:52 PM   #6
Yeah, it really only buzzes in the cold. And generally, the colder it is, the longer the buzzing lasts (as long as I dont take my foot off of the clutch).
And yes, this is the factory starter cut (not alarm) relay.
Also, how do I measure load going to the relay? I guess I can measure current across the coil side w/ my multimeter?
Thanks for all your help Teken......I dont know who else to turn to with this.
Old 01-20-2002, 07:51 PM   #7
Eric R's Avatar
Try just changing the relay for a new one and see what happens...
Eric R is offline   Reply With Quote
main relay buzz Fernan22 Acura Integra 6 06-10-2015 10:50 AM
1996 Honda Civic - cranking Issues Leon999 Honda Civic / Del Sol (1992 - 2000) 40 02-06-2015 02:27 AM
fuel pump Relay? NightHawk92 Honda Accord & Crosstour (2003 - Current) 6 05-02-2014 11:55 PM
2003 Honda Element sometimes won't start caos901 Honda Element & CR-V 4 01-16-2012 03:23 AM
odd buzzing, then ABS light... John Honda Accord (1990 - 2002) 29 09-01-2006 11:34 AM
Tags
accord, buzz, buzzing, car, cut, honda, location, of1990, problem, r1, relay, relays, s2000, solenoid, sound, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
