Viper Alarm Permanent 'Silent Mode' Activation by Remote?
In my 300+ and several Viper Alarm systems (ie 500+, 300, 300ESP, etc.), 'Silent Mode' can be activated by hitting the II button before arming with the I button. In the manual it mentions this is a 'one time action' and if you want Silent Mode permanently, you have to take it to the dealer/installer. When I first had my car (purchased with the alarm already installed), Silent Mode was activated, and my roommate turned off Silent Mode one day playing with my remote. I'm certain there must be a way to do this manually...I've tried endless combinations of buttons and can't seem to figure it out
Old Fart
Re: Viper Alarm Permanent 'Silent Mode' Activation by Remote? (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy »</TD></TR><TR><TD CLASS="quote">In my 300+ and several Viper Alarm systems (ie 500+, 300, 300ESP, etc.), 'Silent Mode' can be activated by hitting the II button before arming with the I button. In the manual it mentions this is a 'one time action' and if you want Silent Mode permanently, you have to take it to the dealer/installer. When I first had my car (purchased with the alarm already installed), Silent Mode was activated, and my roommate turned off Silent Mode one day playing with my remote. I'm certain there must be a way to do this manually...I've tried endless combinations of buttons and can't seem to figure it out </TD></TR></TABLE> Go to http://www.dei.com download the owners manual for the alarm you have 94
Re: Viper Alarm Permanent 'Silent Mode' Activation by Remote? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Go to http://www.dei.com download the owners manual for the alarm you have 94</TD></TR></TABLE>i have the owners manual. in the manual it says the installer must activate silent mode, but since my roomate did it by accident, there should be a way to do it manually with the remote.
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy »</TD></TR><TR><TD CLASS="quote">i have the owners manual. in the manual it says the installer must activate silent mode, but since my roomate did it by accident, there should be a way to do it manually with the remote.</TD></TR></TABLE> Check in the programing sec. it will tell you how to do it in program mode, it may also tell you there how to do it with the remote. 94
sounds like the alarm is in valet mode...Is the LED constantantly on? When you arm it does it blink like normal or is it just a red light?
i beleive theres is a button for valet mode. In my viper alarm not sure what model. You leave the drive door open..turn the key two clicks and hold down both buttons (i have the two button remote) for a couple seconds. Then let go..take out the key and should be back into normal mode.
I've seen a lot of people with the same prob. NO it's not in valet mode and NO there is no programming section in the Owner's Guide. You have to check out the actual Installation Guide used by the dealers.
It shows you how to program every possible feature, including chirp mode on/off.
Note: many of the sirens have internal batteries if reprogramming fails.
good luck
good luck
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I not sure how your friend turn off something that was programmed into the brain. With just the remote and no access to the valet button. Not saying it did not happen but its really not likely. Something must of gliched. What I am wondering is if the dealer gave you the car in valet mode and the alarm was never activated. Just find your valet button and reprogram it back.
500, 5900, activating, activation, activations, alarm, alarms, mode, modes, program, remote, silent, turn, valet, viper
