Techsoft?
Re: Techsoft? (b16 matt)
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Remote Start
12volts white + ignition harness
Starter black/white + ignition harness or
Notes: In 6 pin white plug behind fuse box
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Accessory white/black + ignition harness
Power Lock green/white - keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Unlock Motor blue/red drivers kick panel
Parking Lights+ red/black keyless entry module
Door Trigger lt. green/red - OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Tachometer blue test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Brake Wire green/white + brake switch
Horn Trigger gray - OEM alarm plug
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
TwoFaced
12-16-2010 05:34 PM
choppin_civic
06-10-2006 10:50 PM
