Stock 97 civic lx... Blowing radio fuse & no power to cigarette lighter
Old 06-02-2012, 03:54 PM
Stover954rr's Avatar
Default Stock 97 civic lx... Blowing radio fuse & no power to cigarette lighter
I did a huge search before making this post, but I haven't found an answer yet. I know people have talked about jumping wires, but I keep blowing fuses. PLEASE HELP!
Radio problem:
Every time I turn the key the fuse blows
Cigarette outlet problem: Power to the fuse and through the fuse, but no power to the wire coming out of the fuse box.
What I have done so far:
Check all fuses with multimeter
Checked all grounds
No constant power to radio y/r wire to radio comes on with acc
This is a stock car with no modifications at all, never been modified (as far as I can tell).
PLEASE HELP! I really want to get my dash put back together!
Old 06-05-2012, 06:09 PM
fcm
Old Fart
fcm's Avatar
Default Re: Stock 97 civic lx... Blowing radio fuse & no power to cigarette lighter
Constant power for radio is fuse 47 - 7.5A "back-up" fuse in engine bay fuse box, not under dash fuse box, or are you talking about the radios acc. fuse, fuse 28 - 10A in under dash fuse box.
Is this the stock radio?
Not sure if lighter is on the same fuse, [fuse 47] on a 97 Civic, unplug the lighter, [wire on back of lighter housing] the ligher housing may be shorting out. 94
Old 06-05-2012, 07:20 PM
ef_newb's Avatar
also make sure there's nothing down in the lighter socket.. i've pulled out so many pennies and nickels from "bad" cig lighters
Old 06-06-2012, 02:46 AM
Hi guys,
Thanks for posting up!
I did all of the tests on the cig lighter on the actual wires with the socket removed. Also i am referring to no having power coming from the back of the #27 fuse under the dash.
In this civic there is a separate fuse for the lighter and radio (#27 and #28). Could they be shorting out in the fuse box?
If I turn the car on with the radio unplugged the fuse doesn't blow. When I plug it in, it blows.
I have checked and swapped the 7.5 fuse under the hood even though it looked good.
Old 06-06-2012, 05:41 AM
fcm
Old Fart
fcm's Avatar
If unplugging the the radio prevents fuse blowing the short is in the radio.
If you have power on both test tips of fuse #27 and not on the lead to the lighter then the problem is in the fuse box, [open circuit]. 94
Old 06-06-2012, 11:50 AM
Thank you,
I will order a new radio, but I am confused about the fuse box.... Do I just unplug all the connectors and pull it out? If so what am I looking for?
Old 06-06-2012, 04:02 PM
fcm
Old Fart
fcm's Avatar
It is unlikely the fuse box is reparable, replace it. 94
Old 06-07-2012, 10:17 AM
okay, I ordered a new fusebox and radio. I will let you know the results once I get everything put in. Thank you very much for the help!
Old 07-19-2012, 07:20 AM
Wow talk about being a procrastinator, apparently driving a car with the dash out still isn't enough of a motivator!
Well I put the new fuse box in and...... still no power to the cigarette lighter and the radio fuse still blows.
With the new radio in however...... The radio works and the fuse doesn't blow!!!
So the radio problem has been solved.
Can anyone point me in the direction as to where the Accessory Plug (Yellow/Green) wire comes out of the fuse box. Also is there a relay in this circuit?
Old 07-31-2012, 03:09 PM
just to update and close the thread. The problem was a cut wire hot wire to the cig lighter. all is fixed! Thanks honda tech
osbunjosh
50
01-29-2024 05:20 PM
thomaswjparker
03-24-2014 06:59 AM
IP RACING
11
05-06-2008 08:31 PM
pinkspider
Audio / Security / Video
10-23-2006 02:11 PM
cd5_2NR
07-01-2004 01:38 PM
Quick Reply: Stock 97 civic lx... Blowing radio fuse & no power to cigarette lighter
