Speaker suggestions? - Honda-Tech
Old 04-20-2012, 01:58 PM   #1
Default Speaker suggestions?
I just replaced my head unit in my 97 Civic. I am running a Sony CDX-GT660UP and I would like some more up to date speakers to compliment the new unit as cheap as it may be. I do not want anything too expensive. I am looking for something with clear sound and decent bass. The car came with some older PowerBass 6.5 and 6x9 coaxial speakers but when they are cranked up to 15 on the unit's volume control, there is a bit of distortion and the bass sounds "muffled". What are some good suggestions around the or less than $100 for 6.5 and under $150 for the 6x9? Like I said, I am not looking for over the top high end speakers. I just want an upgrade with crisp and clean sound with enough bass to sooth the ears.
Sagara09 is offline   Reply With Quote
Old 04-20-2012, 05:15 PM   #2
gzes's Avatar
Default Re: Speaker suggestions?
I use kicker on everything car sound related. It's not expensive and sounds great. I just ebay them and pop em in and they are beast
gzes is offline   Reply With Quote
Old 04-20-2012, 08:55 PM   #3
90_EX_Civic's Avatar
can't go wrong with rockfords, and looks like amazon has a sale on them,
http://www.amazon.com/Rockford-Fosga...1997&carId=001
90_EX_Civic is offline   Reply With Quote
Old 04-20-2012, 09:50 PM   #4
fcm
Old Fart
fcm's Avatar
Infinity speakers.
Keep in mind the speaker install will have more to do with SQ then the speaker you buy, the same goes for the HU, I am guessing the aftermarket HU was installed using and adapter harness, so all stock HU wiring, [speaker wiring, power and ground wiring] is being used.
If so, you are under-powering the HU, the stock 12V+ constant and ground lead can not supply the aftermarket HU with the current it needs, especially when the volume is turned up.
This needs to be fixed before you get new speakers.
The "fix", run a fused 12ga, [40A max] from the batt. pos.(+) to behind the HU, connect the HUs 12V+ constant, [yellow] to it, don't forget to cap off the stock 12V+ constant, [or depin the lead from the adapter harness if used].
Run a 12ga lead from the HUs chassis to the cars chassis, [dash subframe will work], if the HU is back braced to chassis ground, [stock rear support bar] as it should be, a 12ga ground is not needed, leave the stock wire ground in place. 94
fcm is offline   Reply With Quote
Recommend on speaker? crxb16a90 Audio / Security / Video 4 02-07-2011 09:21 PM
Great 6.5 Component Speakers? SIRIUS VTEC Audio / Security / Video 12 05-11-2008 12:45 PM
ef hatch system noob nice bass without subwoofer DIYMIKE Audio / Security / Video 6 02-14-2008 04:41 PM
best speaker setup for 96 coupe... awdriscol4 Audio / Security / Video 1 02-09-2005 10:58 PM
What Audio Setup for GSR Sedan? joeg26er Audio / Security / Video 2 07-07-2002 06:03 PM
Tags
2001, 65, 6x9, accord, cdxgt660up, civics, coaxial, connecting, distorted, good, honda, hu, kicker, replace, running, sony, speakers, tech, them
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
