SLENCER CAR ALARM HELP... - Honda-Tech
Old 09-18-2008, 07:21 AM   #1
Banned
Black LeX's Avatar
Default SLENCER CAR ALARM HELP...
SO I REPLACED THE BATTERY ON MY ALARM SINCE IT DIED, ONCE I PUT THE NEW BATTERY IN THE LED ON THE REMOTE STAYED ON.....
HOW DO I programme IT SO MY CAR RECOGNIZES IT????
ANYONE HAVE A SILENCER ALARM THAT KNOWS THE STEPS TO DO THIS?
Black LeX is offline   Reply With Quote
Old 09-18-2008, 12:35 PM   #2
B18C_EJ8's Avatar
Default FV-QR
First step, turn caps lock off.
After you've completed step 1, let us know.
B18C_EJ8 is offline   Reply With Quote
Old 09-18-2008, 02:10 PM   #3
Banned
Black LeX's Avatar
ok they're off.....
Old 09-18-2008, 09:13 PM   #4
Davus's Avatar
Is this a DEI alarm? If so,
http://www.drdetailshop.com/remoteprogram.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1) Open a door and make sure the dome light is on.
2) Turn the ignition on to the RUN position or you may also start car.
3) Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction Here)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4) Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5) Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6) Once the code(s) are learned, the Valet/Program push button can be released.</TD></TR></TABLE>
If not, reply back with model of alarm, but that's pretty much a universal way of programming remotes. :D
Davus is offline   Reply With Quote
Old 09-19-2008, 07:47 AM   #5
Banned
Black LeX's Avatar
ehh, its not a dei brand, its an el cheapo brand that came w/ car when i bought it....
at this point im not even sure if the remote is the rigth one for the brain unit haha
usually when u push the remote it will recognize it......
idk
fubarglasted
DEI 520T not working rugimpy Audio / Security / Video 5 03-18-2011 08:22 AM
91 Honda Accord Car Alarm won't de-activate mohunny Honda Accord (1990 - 2002) 4 09-07-2009 05:30 PM
Bad battery? VTECROAR96typeR Acura Integra Type-R 3 05-25-2009 03:13 PM
00 civic si factory alarm boostedsi21 Audio / Security / Video 2 06-15-2007 07:18 PM
Anybody using a Black Widow BWN-500P 2 way paging Alarm in their TYPE R ?? xunkn0vvnx Audio / Security / Video 1 11-21-2004 09:30 AM
Tags
alarm, alarms, auto, brand, car, disarming, honda, program, programming, push, remote, silencer, switch, transmitter, valet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
