Security...for a sub?
Old 01-14-2007, 04:54 AM
Mitsu's Avatar
Default Security...for a sub?
Going to put in a sub for my car. First sub i've gotten, wondering if it's common at all for them to be stolen? I'm building the enclosure myself, should I put some sort of locking mechanism on it so I can secure it to the trunk.
Old 01-14-2007, 05:03 AM
H22CD7's Avatar
I wouldnt bother. Anything that thieves cant get out/take quickly tends to get destroyed either while trying to get it out or just because they are pissed. I would just get a nice 2 way paging alarm and call it a day. Once there in your car the damage is done so I would focus more on trying to stop it before that point.
Old 01-14-2007, 07:35 AM
fcm
Old Fart
fcm's Avatar
Default Re: Security...for a sub? (Mitsu)
It should be secured in the trunk somehow anyway, keep it from bouncing around, as has been mentioned, if they want it they will get it or destroy it, if box is secured they will just unscrew the sub.
Here's a trick though, disconnect the trunk release cable, so a key is needed to get into the trunk, and if you really want to mess with the crooks head, connect the release cable to a switch that will supply a ground to a relay that is connected to the cars horn. 94
Old 01-14-2007, 07:38 AM
H22CD7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and if you really want to mess with the crooks head, connect the release cable to a switch that will supply a ground to a relay that is connected to the cars horn.</TD></TR></TABLE>
hahaha, thats awesome. I'm definitely going to have to give that one a try.
Old 01-14-2007, 08:36 AM
NO MERCY!
RICO_'s Avatar
Default Re: Security...for a sub? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> and if you really want to mess with the crooks head, connect the release cable to a switch that will supply a ground to a relay that is connected to the cars horn. 94 </TD></TR></TABLE>
lol. Bet the crook will never see that one coming. Never thought of that before.
Old 01-14-2007, 10:43 AM
02 accord's Avatar
Default Re: Security...for a sub? (RICO_)
Put an air horn inside the car (hooked up to the previously mentioned switch) and aim it at the trunk release lever. Once he pulls that lever, I'm sure he wouldn't want to try it again.
Edit: aim it not at the lever itself but at the area where the crook would be.
Modified by 02 accord at 4:27 PM 1/14/2007
Old 01-14-2007, 03:57 PM
Mitsu's Avatar
Default Re: Security...for a sub? (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Put an air horn inside the car (hooked up to the previously mentioned switch) and aim it at the trunk release lever. Once he pulls that lever, I'm sure he wouldn't want to try it again.
Modified by 02 accord at 4:27 PM 1/14/2007</TD></TR></TABLE>
lol this is awesome, there a DIY for this? where would you put the air horn? under the seat?
Old 01-15-2007, 09:32 AM
02 accord's Avatar
If I were doing it, I would stick it in the left side air vent. Some of the vent tubing would have to be cut to allow the horn to blow into it. There should be enough room behind the vent for the horn so that it isn't inside the tubing and doesn't restrict air flow to the vent.
Old 01-15-2007, 11:21 AM
8520's Avatar
Awesome idea fcm
Mitsu: If I were you I'd look in to stealth systems. If they can't see it, they don't know you have anything worth stealing
deerman2701
Audio / Security / Video
07-10-2008 11:50 AM
Blazin Civic
02-13-2006 07:55 AM
spicoli
11-08-2004 11:02 AM
dgdarien
12-22-2002 09:54 AM
Quick Reply: Security...for a sub?
