Removing 2003 Honda Civic Hybrid Factory Installed Car Stereo??? - Honda-Tech
Old 06-01-2005, 07:03 PM   #1
onevim's Avatar
Default Removing 2003 Honda Civic Hybrid Factory Installed Car Stereo???
Hello everyone,
I've been looking everywhere for a good resource on how to remove a factory installed car stereo for the 2003 Honda Civic Hybrid, but with no luck. I'd appreciate it if someone could point me in the right direction. Thanks!
onevim is offline   Reply With Quote
Old 06-01-2005, 08:46 PM   #2
fcm
Old Fart
fcm's Avatar
Default Re: Removing 2003 Honda Civic Hybrid Factory Installed Car Stereo??? (onevim)
Remove trim panel that lighter is mounted on, [it pops out] it's held in with,"the trim panel clips from hell" so it may be hard to do, after removing you can look/feel up there an find and remove 4x8mm machine screws, this will allow you to remove the radio and climate control housing, also held in with "the clips from hell. Avoid the temptation to stick a screwdriver in around the edge of the housing, you will only mark it all up, once you have remover the 8mm screws you can put enough pressure from behind, [be careful some of the metal edges back there are sharp] to start popping it out, enough to get your fingers in around the edge of the housing, try and pull it out as square as possible, to much on one side or the other or top or bottom will only bind the housing and you can do damage to the the "clips" or the slots the "clips" clip into. go to http://www.installdr.com and bring up the 99/00 Civic, its not the same but close enough to help, go right to step 9 as you will not have to remove all that other stuff in your car. Hope this helps 94
fcm is offline   Reply With Quote
Old 06-03-2005, 12:24 PM   #3
onevim's Avatar
Default Re: Removing 2003 Honda Civic Hybrid Factory Installed Car Stereo??? (fcm)
Thanks for the help. Quick question though: Where are these "trim panel clips from hell" located...the ones that i need to remove the cigarrette lighter trim panel. thanks again!
Old 06-03-2005, 03:23 PM   #4
fcm
Old Fart
fcm's Avatar
They are the ones that hold the trim panel on, I think there are 6 of them, two on the top of the T/P and two on each side of the T/P, they are attached to the trim panel, the panel will "unclip" if you pull it hard enough, if it's the same as on a Civic 94
Climate control (CC) lights with aftermarket stereo martik777 Audio / Security / Video 4 08-09-2016 02:03 AM
94 honda accord factory stereo removel portugueboy10 Honda Accord (1990 - 2002) 2 09-03-2012 06:00 PM
iPod Installation 2003 Civic Hybrid? s_paulik87 Honda Civic (2001 - 2005) 2 06-25-2010 07:43 AM
Factory Stereo says "Code" slowNbroke Honda Civic (2001 - 2005) 3 06-18-2006 12:14 AM
factory stereo removal question JG99 Honda Prelude 3 11-05-2002 02:01 PM
Tags
2003, 2005, car, civic, factory, honda, hybrid, installed, panel, radio, removal, remove, removing, stereo, trim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
