viper alarm emergency... pls help
Old 01-07-2007, 01:22 PM
type B16's Avatar
Default viper alarm emergency... pls help
my bro is in nyc right now and his alarm wont recognize his remote. this just happened out of nowhere. if its anything like my viper, he wont be able to start the car. he changed the remote battery but its not it.
what are his choices in order to actually getting the alarm off and starting the car with the key?
Old 01-07-2007, 01:32 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: viper alarm emergency... pls help (type B16)
can he find the valet button?
Old 01-07-2007, 01:50 PM
type B16's Avatar
Default Re: viper alarm emergency... pls help (wrx-killer-Sti eater)
thats what i told him. no idea where it is. cant contact the installer
Old 01-07-2007, 03:45 PM
B18C_EJ8's Avatar
Well, unless you can locate the switch to try to reprogram the remote, you're sortof stuck...
Can you find the brain to the alarm?
Old 01-07-2007, 03:51 PM
type B16's Avatar
Default Re: (B18C_EJ8)
valet switch was found.
now trying to manually disarm the alarm is the problem
Old 01-07-2007, 04:16 PM
B18C_EJ8's Avatar
You'll need to know how many presses the button is programmed for.
Then, you get in, turn the key to "on" (don't start the car), and press the valet switch the predetermined number of times. Usually, it's default is one press.
If it's been changed and you don't know the number, you're beat.
Old 01-08-2007, 04:49 PM
suspendedHatch's Avatar
If it's the two way paging LCD remote, hit the little button on the back until you see a little 1 on the LCD screen.
Check the antenna connections at the antenna and the brain. They may look okay, but make sure they're fully inserted and have some slack.
Then check the battery and ground connections. I've found that a weak ground can cause bad reception but the alarm will still seem to work.
BTW, if the alarm isn't armed, you'll be able to start the car just fine since the default start kill setup is normally closed.
JDanyM
Audio / Security / Video
03-06-2011 10:44 AM
lickety_britches
11-27-2008 09:07 PM
8krdline
09-15-2005 05:21 AM
I Gotta Question
01-26-2004 07:33 AM
JL 74
12
01-09-2002 09:48 AM
Quick Reply: viper alarm emergency... pls help
