Python alarm installation need help!!
Old 01-23-2015, 09:52 AM
davidzhou4893's Avatar
Default Python alarm installation need help!!
I brought python alarm 5303 alarm online, it came with all the wires and stuff but it didn't have a manual or anything but there's a diagram, I was wondering if anyone can help me figure out what wires go where, installing on a 98 civic, i also got the diagram for the civic, thanks in advance for the help.
Old 01-23-2015, 06:24 PM
Clean98EJ8's Avatar
Default Re: Python alarm installation need help!!
I also recently installed an alarm. The 12v.com has some wires and locations. I have a good amount of wiring experience and I will tell you that installing an alarm is not a easy job if you do it right. Ideally the alarm should not be easy to locate or remove. If you need some pictures there are a few pics on here if you search that show exactly where to install at. If you are looking for a quick install it will work fine. I went a different route and removed the whole dash and wired in very deep and none of the wires are accessible without the dash out. In fact if you search my posts you will find wire colors and locations.
Old 01-24-2015, 07:42 AM
Thanks a lot I appreciated.
Old 01-26-2015, 06:29 AM
MotoCARR's Avatar
Regular & quick reference install manuals as well as owner's manual attached
File Type: pdf
File Type: pdf
File Type: pdf
Old 01-26-2015, 06:31 AM
MotoCARR's Avatar
Wire colors
https://honda-tech.com/audio-securit.../#post50130898
dragonfly2k3
Audio / Security / Video
12-20-2007 05:34 PM
Jdmglenn
10-13-2007 04:34 PM
Otherguy
04-21-2005 01:59 PM
CrXRaCer86
03-17-2002 01:37 PM
Quick Reply: Python alarm installation need help!!
