need help on viper 300 install
Old 10-27-2004, 03:18 PM
silvervtecrx's Avatar
Default need help on viper 300 install
well i salvaged a viper 300 off of my moms car coz she is selling her car so I have tried searching and i cant seem to find a website or here on h-t on a guide for the install of this alarm..
well i need help on the install if anybody could direct me to a good website or anyone who has know-how on installing a viper 300 HELP ME OUT..
it will be put into my EG...
edit:
where do i put do door trigger zone wire(+) and (-),, and also the intant trigger zone....
Thanks in advance..
Modified by silvervtecrx at 7:44 PM 11/2/2004
Old 10-27-2004, 05:02 PM
92eg-pa's Avatar
Default Re: need help on viper 300 install (silvervtecrx)
i think i have an install book on that in my tool box, let me check, i can send you the wire colors then
Old 10-27-2004, 09:16 PM
fcm
Old Fart
fcm's Avatar
Wireing for alarm should be on the back of the alarm brain
Wire tagin on your car you can get at http://www.bulldogsecurity.com 94
Old 10-27-2004, 09:26 PM
Default Re: need help on viper 300 install (fcm)
thanks.. bull dog security solve my question..
Old 11-02-2004, 06:44 PM
bump
Old 11-02-2004, 06:50 PM
where do i put the door trigger zone wire(+) and (-),, and also the intant trigger zone....
Old 11-02-2004, 08:09 PM
bizzump
Old 11-02-2004, 10:53 PM
bizzzzzzzzzzzzzzzzuuuummmmmmppppppp
Old 11-03-2004, 07:13 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvervtecrx &raquo;</TD></TR><TR><TD CLASS="quote">where do i put the door trigger zone wire(+) and (-),, and also the intant trigger zone....
</TD></TR></TABLE>You will use the (-) door trigger for the doors, [ light green/ red in kick panel or fuse box most Hondas] the (+) you will not use, and the instant trigger would be user if you are adding another sen. 94
PS what year is your car?
Old 11-03-2004, 03:15 PM
95 civic hatch
Old 11-03-2004, 04:51 PM
lvmyhnda's Avatar
easy
brain wires... you will use
red-12v
yellow-ignition
green-negative door trigger input
white-positive parking light out put
black-ground
lock harness on side
green-lock output
blue-unlock output
dont wory about the white and brown wires
purple-you are going to put to ground
now some viper 300's have a different lock harness you may just have a two pin white plug with green and blue .. if so good less headache for you
now car wires
12v - white at the ignition harness
ignition - black yellow at the ingnition harness
negative door trigger - light green red in the drivers kickpanel or you can go to the
switch itself.. or fuse box
parkin lights - red black at the fuse box or dimmer
negative lock - green white at the drivers kick panel
negative unlock - green red at the drivers kick panel
now brown from the brain is going to go to the red wire on the siren and groung the black wire on the siren.
no starter kill is an option.. if you have two thick black wires on the side of the brain its easy just find the black white starter wire at the ingnition harness and cut it in halfput one of the black wires to one side and the other black wire to the other side. if you have a relay then orange from the brain is going to go the the orange wire on the dei relay that comes with the alarm other relays have different colors so ... now green on relay goes to the key side of the starter wire that you cut and black goes to the starter side of the start wire . red goes to 12v
hope this answers your questions..... website to go to is http://www.directechs.com password is c952iov and it will give you diagrams of wires for all cars and manuals for all dei alarms and products..
Old 11-04-2004, 07:56 AM
Default Re: need help on viper 300 install (lvmyhnda)
can i wire the brown wire which is for the siren to the cars horn? nd if so how?
(the alarm doesnt have a siren wen i salvaged it)
thanks in advance.
Old 11-04-2004, 08:00 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvervtecrx &raquo;</TD></TR><TR><TD CLASS="quote">can i wire the brown wire which is for the siren to the cars horn? nd if so how?
thanks in advance.</TD></TR></TABLE> you have an IM 94
Old 11-07-2004, 02:03 PM
lvmyhnda's Avatar
no you can not hook the siren out brown wire to the horn seeing as how the horn is negative trigger and the siren output brown is positive out.. but you can use a relay..brown goes to pin 85, ground pin 86 and 30,pin 87goes to the horn on the car.. its easy.. any thing else let me know..
Old 11-10-2004, 06:50 AM
lvmyhnda's Avatar
sorry i cant use im. are you using a relay? if not it will not work.. you have to use a relay.. look the easiest thing to do is to go to a local circuit city and get a code alarm siren. there like 25 bucks or so..
Old 02-15-2013, 09:29 AM
seas2day's Avatar
Originally Posted by ;12288301
easy
red-12v
yellow-ignition
black-ground
green-lock output
blue-unlock output
now car wires
This post has been a HUGE help in figuring out how to wire an old Viper 300 I had from the 90's but was pulled out of the car it was installed in.
If you are still around, do you by chance know where the black wire of the Valet switch is supposed to go? That is the one thing I am still not sure of.
Thanks a LOT for your great post!
Cheers,
Adam
jdm_xsi206
07-13-2010 08:41 PM
Enzo Speed
Audio / Security / Video
14
08-10-2006 09:03 AM
wantasol
07-23-2006 11:53 AM
Quick Reply: need help on viper 300 install
