Integra power antenna
Old 12-30-2010, 04:19 PM
MurtazaDSM's Avatar
Default Integra power antenna
I have a pioneer Deh-6000ub but I dont know where to connect the power antenna wire to. The Pioneer harness only has a blue/white wire(System Remote Control). No solid blue wire for power antenna signal.
I only want the antenna to stay up when I listen to the radio occasionally but not up when listening to a cd or ipod. I had a Alpine cde-7858 and it had a power antenna wire and the antenna would only come up if the radio was on. Is there any way I can wire it to do the same with the pioneer?
Old 12-30-2010, 07:12 PM
MurtazaDSM's Avatar
Default Re: Integra power antenna
bump
Old 12-30-2010, 07:16 PM
Ridin Dirty in Cali
dirty19's Avatar
It should work and bring up the antenna when the car is switched on.
Give it a shot.
Old 12-30-2010, 07:26 PM
Cobb2819's Avatar
the question was how to wire up a power antenna circuit with an actual power antenna output
Old 12-30-2010, 07:35 PM
Ridin Dirty in Cali
dirty19's Avatar
Ahhhh Gotcha! I guess the remote isnt the same thing?
Old 12-30-2010, 07:45 PM
Cobb2819's Avatar
the remote sends 12v when the head unit is on. the power antenna typically only outputs when the am/fm tuner is on. switch to cd or USB and the power antenna wire stops working
Old 12-30-2010, 08:44 PM
MurtazaDSM's Avatar
so should I connect it to my remote wire?
Old 12-30-2010, 08:48 PM
Cobb2819's Avatar
yes, but the antenna will be up whenever the radio is on. you're just gonna have to deal with that.
Old 03-27-2011, 07:17 PM
bonstokLS's Avatar
I had a Pioneer head unit and it was wired so it would only come on when the radio was on. That is how I wanted it. I now have a different integra and a Sony Head unit. It now is wired on so the Power Antenna comes up whenever the radio is powered on. LAME.
Anyone know how to wire it so it comes on when I switch the radio on?
Old 03-28-2011, 08:19 PM
fcm
Old Fart
fcm's Avatar
Use the system remote control lead, blue/white, connect to 1A on/off switch and connect power ant. control lead, [ant. side] to other side of switch, then you can keep ant. down when not using the radio. or get a HU with an ant. control output lead, only two ways I can think of doing it other then paying a technician to add an ant. control output lead to the HU you have, [probably cost more then to replace the HU]. 94
Old 03-29-2011, 05:08 PM
rjr162's Avatar
Like fcm said.. and it really depends on the line of Pioneer... the higher ends tend to have both a P Ant and a Remote turn-on.
NFrank89
01-16-2010 07:32 PM
SanJose408
Audio / Security / Video
03-27-2008 09:13 PM
sixtodc2
10-01-2006 10:47 PM
crafty
08-26-2003 10:19 PM
.MilanoRex
04-15-2002 05:53 PM
Quick Reply: Integra power antenna
