Installing a Pioneer AVIC-F500BT On-Dash Nav in a 2007 Honda Accord EX Sedan
Hi, I could use some help installing a Pioneer AVIC-F500BT On-Dash Navigation System in my 2007 Honda Accord EX Sedan. As of right now I have already connected the Audio Output to the Honda's factory radio using the Blitzsafe HON/AUX DMX V.2X Aux input adapter. For power I am using the DC 5V Vehicle power charger cable connected to my in-vehicle power port socket (a.k.a. Cigarette lighter). But I would like to power the F500BT with out using the Cigarette lighter socket. I believe (but I'm not certain) that I can use the Nav unit's Yellow Battery Cable for this purpose. The connection diagram (attached to this post) says "Be sure to connect this lead to terminal always supplied with power regardless of ignition switch position." My problem is that I just don't know where to connect this cable in my car. I have the tools and knowledge to get the dash and center console open but I don't have the knowledge to know where this Yellow Battery Cable would connect and could really use some help. Even if I did figure this out, would connecting this cable be an alternate way to power the Nav unit with out needing to connect it to my Cigarette lighter? Thanks in advance for any help anyone could provide.
Re: Installing a Pioneer AVIC-F500BT On-Dash Nav in a 2007 Honda Accord EX Sedan
you could tap that fused wire into your constant 12v ignition wire which is Plain white, Or you could just run it directly to the Positive side of your battery. I'm not sure if your 12v socket stays live after key removal but test it to be sure and then you can tap the wire from there as well.
I just did some research and found out that the 07 accords may not have constant power to the cigarette lighter once the key is removed, i may be wrong but you must double check to be sure, also the white wire i was talking about is in the ignition harness (Steering column) if you do not want to take that section apart, you can run a wire directly to the battery and fuse it 12 inches or less from the battery.
That's okay man, we all gotta start somehow right? Here's an idea.. post a pic of the fuse box on the passengers side and the wires around it if possible, If there is a green wire there you can tap into it, It has 12v and is constant. would be a whole lot easier than running a wire to the battery because your battery is practically by the headlight if i'm not mistaken.
I tested the cigarette lighter and you were right, it's not constant power. I'll try to get a pic of the fuse box and post it soon; good idea.
On another note, I'm actually considering calling Pioneer and asking them why this cable needs to be connected to a constant power source. Before attempting this internal installation I just connected the Nav unit to the cigarette lighter port with the supplied power cable. I'm not understanding why it would need to have constant power with the internal installation setup. I feel like that might be a drain of my battery, but I guess I could be wrong.
Old Fart
Just run a fused lead from the batt. and connect the yellow 12V constant, [Battery Cable (yellow)] to it, don't forget the fuse on the lead you run, put it as close to batt. as possible. 94
Mikerugg
11-29-2018 11:41 AM
geigerm
01-30-2013 10:01 PM
Fugun
08-11-2004 07:55 AM
