installing the headrest dvd
Re: installing the headrest dvd
the last set i did for a friends car i used a #10 blade scalpel (a sharp xacto knife works), a tape measure, and a teaspoon from the kitchen. id recommend picking up a donor headrest from as identical a car as you can find to practice on first. any job is easier the second time, might as well make the second time on the one that actually counts. on the practice one, make sure you make a good log of your measurements for centering and for depth of mounting
1. Remove your existing headrests.
2. Put our headrest units and all of the cables go through the holes of poles on the headrest, through the seats and under the carpet upholstery.
3. Connect the power cable with 12V car power supply. Red wire is for the positive pole while black wire is for the negative pole. If you have our cigarette lighter adapter, this item can be powered by your vehicle’s cigarette lighter.
