Hwo do I disconnect my power antenna??? - Honda-Tech
Old 04-24-2004, 12:35 PM   #1
_Bug_'s Avatar
Default Hwo do I disconnect my power antenna???
Well its not on my car but on my girlfriends 4 runner. Her power antenna retracter thing is broken, you know the thing that makes the antenna go up and down. She only listens to CD's and never the radion so she really doesnt need the antenna up, nor have the desire to fix it. So one day I pused it down because I was going to put it in the car wash. Now everytime I change the CD or turn of the car, I can hear the motor making an annoying noise, I guess trying to pull the antenna back down.
So my question is how do I disconnect the antenna so it doesnt make that noise anymore? Should I remove a fuse? Should I try disconnecting it from the radio? Please help me out here, any info would help.
_Bug_ is offline   Reply With Quote
Old 04-24-2004, 02:02 PM   #2
john666's Avatar
Default Re: Hwo do I disconnect my power antenna??? (JDM_Bug)
hmmm... im sure you could alwayz find the power antenna wire behind the stereo and disconnect that.. or if it would be easier, disconnect the power wires near the antenna motor.
john666 is offline   Reply With Quote
Old 04-24-2004, 09:30 PM   #3
rjr162's Avatar
Default Re: Hwo do I disconnect my power antenna??? (john666)
Quote:
ok, a question for you. Did the antenna use to go up when the radio was on, and come back down when the CD mode was selected? If so, then you can just cut the power antenna wire and you're fine. But if the antenna was up any time the head unit its self was on, then cutting that wire may not be an option.
Alot of toyota's, such as the 4runner, use a small factory amp located down behind the radio to run the speakers. If you just cut the power antenna signal wire, you'll also be cutting the factory amp's turn on signal wire. if you do this you'll have no audio at all. In that case you'll have to actually disconnect the signal wire from the antenna unit its self, or somewhere between where the signal wire turns on the factory amp and the antenna unit its self.
rjr162 is offline   Reply With Quote
Old 05-03-2004, 11:50 AM   #4
Moderator in Chief
Muckman's Avatar
Muckman is offline   Reply With Quote
Half Antenna/ Antenna Help! MUGENBB4JDM Tech / Misc 0 11-06-2012 03:48 PM
Antenna wont go up (help) DJLikwid Acura Integra 14 08-22-2012 02:39 PM
Replacement Antenna bopbop93030 Honda Accord (1990 - 2002) 5 05-19-2008 05:25 PM
Bad Mechanic Mike1995HondaPrelude Honda Prelude 12 08-10-2007 04:29 PM
My power atenna is busted and it is making a noise.. Captain Flaps Honda Accord (1990 - 2002) 7 11-08-2005 04:23 PM
Tags
2001, 2004, 4runner, accord, antenna, car, cut, disconnect, disconnecting, honda, integra, motor, power, stereo, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
