Honda Pilot - radio won't work after battery change - Honda-Tech
Old 02-10-2010, 05:50 PM   #1
New User
Default Honda Pilot - radio won't work after battery change
The battery in my Honda Pilot died completely - to the point where it could not be jumped. After replacing the battery - they found that two fuses had blown. The issue is that the radio will not power on - I'm not even getting the 'code' request. The 'lighter' has power from it, so the repair man is telling me that since the 'lighter' is working then the radio is probably blown... should I still try changing the fuses? If so, which ones should I replace?
Thanks,
Radioless...
walkergirl is offline   Reply With Quote
Old 02-11-2010, 04:05 AM   #2
audioroach's Avatar
Default Re: Honda Pilot - radio won't work after battery change
normally there are 2 power sources for the radio: accessory and battery.
Check all fuse boxes (underdash and engine bay) with a meter - if the fuse is okay should read voltage on both sides.
audioroach is offline   Reply With Quote
Old 02-15-2010, 08:37 AM   #3
cdx280's Avatar
you could also try disconnecting the radio and plugging it back it. once in a blue moon this has worked for me. the radio might have some residual voltage thats letting it keep its memory and unplugging it will reset it. chances are you're gonna need to go back to the dealership to get the code once its turned back on tho.
cdx280 is offline   Reply With Quote
Old 07-08-2011, 07:20 AM   #4
I have the same problem with the radio of my Pilot (nothing on radio and lighter is fine) after I mistakenly connected the battery (positive to negative). I replaced the burnt 120A fuse and now the radio doesn't work. I checked the fuse box and radio and lighter is on the same fuse. I guess I have to replace the radio. Any advise is appreciated. Thanks.
jyuan87 is offline   Reply With Quote
Old 07-09-2011, 05:09 AM   #5
rjr162's Avatar
Did you check *both* fuse locations? The constant feed should be in the under hood fuse box, while the accessory feed will be in the fuse box under the dash.
rjr162 is offline   Reply With Quote
Old 07-09-2011, 08:43 AM   #6
OK, I found the fuse, which is 20A RADIO under hood. I didn't find it before because dirt block letter R and made it look as "HADIO". The radio works after I changed the fuse with a 15A as I don't have a 20A. Thanks.
Radio and cigarette lighter don't work Andrew LaRussa Honda Civic / Del Sol (1992 - 2000) 5 08-08-2015 04:13 PM
92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue Mykul Honda Accord (1990 - 2002) 7 12-04-2013 07:56 AM
Radio not working 2Accords Honda Accord (1990 - 2002) 2 08-20-2011 08:34 PM
Radio not working fortymcpants Audio / Security / Video 5 08-02-2008 02:10 PM
HELP! Radio and lighter went out, fuses are good, What now! tfalconier Honda Civic / Del Sol (1992 - 2000) 1 12-20-2003 08:05 PM
Tags
05, 2005, 2010, accord, battery, change, changing, console, honda, issue, pilot, radio, replace, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
