Little help with my basslink install
I can't find anywhere to ground this thing (93 civic 4dr).. Everything is painted metal
If anyone has any pics of where they grounded their system, I would really appreciate it.
Also I'm having a hard time finding a way to get the 8ga through to the battery. Some of you said go through the firewall, not really sure where to do this. Pics would be greatly appreciated.
Thanks
Thanks
Re: Little help with my basslink install (fod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fod »</TD></TR><TR><TD CLASS="quote">I can't find anywhere to ground this thing (93 civic 4dr).. Everything is painted metal
Thanks</TD></TR></TABLE>
you can put a ground somewhere under the seat. I did that.
but then again, I dont know HOW painted your car is.
AS for the power wire, just look for a hole through the firewall. Some have plastic plugs. Or use he ecu side hole from the engine bay to the inside.
I have a basslink as well! good stuff for less space! If you need pics I can get em. Its an integra though
look under your hood by the battery.if you are looking at the battery head-on, there is a grommet down below to the right of it. run your wire through there.
