Help! Power locks don't work! - Honda-Tech
Old 12-24-2011, 10:16 PM   #1
Danny Sihapanya's Avatar
Default Help! Power locks don't work!
Hi.
I have a 99 Civic LX with power locks.
It works 10% of the time. The 90% of the time is slamming the door REALLY HARD to make them work.
I have no idea what could have caused this.
My power door locks would work but ONLY if I slam my door 2-5 times HARD.
It happens when I lock it outside and inside.
Plus, I am a beginner and 16. So keep it simple please.
Thank you for reading!
Danny Sihapanya is offline   Reply With Quote
Old 12-25-2011, 11:53 AM   #2
fcm
Old Fart
fcm's Avatar
Default Re: Help! Power locks don't work!
My guess is broken leads in the door jamb boot, it is a common problem, mostly on the drivers door as it is used, [opened/closed] far more then pass. door. 94
fcm is offline   Reply With Quote
Old 12-25-2011, 08:50 PM   #3
Is it an easy fix?
Is it expensive to fix? DIY?
Old 12-26-2011, 01:23 PM   #4
fcm
Old Fart
fcm's Avatar
It is a bit of a PITA, the best way is to unplug the door harness at the A pillar, remove door panel and speaker and pull the door jamb boot, [and harness] into the door and then out the speaker opening, that way you can remove tape and slide the boot down the harness to access the damaged part, [or to see if there is damage].
Hint, just because you do not see broken leads does not mean there is no damage, pull on each lead, if it "stretches" the wire is broken inside the insulator, [common].
The best way to repair the wire is to cut a section out and add a longer lead and connect, [solder and shrink tube] at each end, that way the "bending" will not be at the connection, the best possible fix is to replace the door harness. 94
Old 12-26-2011, 08:35 PM   #5
I don't have a clue to what you just said but thanks!
Replace door harness. Got it!
Old 12-27-2011, 01:37 PM   #6
fcm
Old Fart
fcm's Avatar
Replacing or repairing the harness is pretty much the same, as far as getting the door harness out to replace it or repair it.
Broken leads in the door jamb boot is only a possible problem, you need to check before you go and replace the harness. 94
Old 12-27-2011, 10:53 PM   #7
Okay. I'll probably get a friend on it.
5th gen Prelude Power Door Lock! hondamyheart Honda Prelude 0 12-08-2016 12:37 AM
01 Coupe Door lock Problems Vic3261 Honda Civic (2001 - 2005) 3 07-02-2012 05:28 PM
Help, Doors wont lock si_motor_spt Honda Prelude 3 05-30-2010 02:14 PM
How hard would it be to install alarm and add power door locks on a 96 EK??? Slammed Ek9 Audio / Security / Video 1 03-15-2005 03:45 PM
DOOR Lock problem EGPrelude Honda Accord (1990 - 2002) 21 06-25-2004 03:51 PM
Tags
99, acura, auto, back, civic, crv, dont, door, honda, lock, locks, power, problems, s2000, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
