Electric problems
Electric problems
I'm having some odd electrical problems and would like to fix them before installing an alarm. The pictures below are of some cut wires that I have no idea where they go. The first pic is a cut ground wire that is attached to the steering column. The second picture is a purple wire, looks black, and is located by the drivers kick panel. Any input would be greatly appreciated.
Old Fart
Re: Electric problems
The purple wire is aftermarket, you can just remove it.
The black wire I am not sure of, can't remember a Honda/Acura that uses a steering column bolt for a ground.
What is the MM&Y of the car?
What electrical "problems" are you having?
Well, the first click of my headlight switch, nothing lights up. When I click it twice everything does work as it should. I'm just trying to figure out why nothing works when I only click it twice. Also, my dome light only works when the headlights are on. There's also some more issues...
cmross13
10
02-27-2010 11:39 AM
ScottEK
Audio / Security / Video
07-23-2003 10:06 AM
