Clifford 50.5x remote wont start help
When i try to remote start it it would crank then stop at first i thought it bc my car battery was dying so i got it replaced n its still doing it. on occasions it would start right up but most of the time it would crank up n just die. i can start it up fine w the key.
any tips? i tryed searching the fourms before i posted this couldnt find anythin useful...thanks guys
Old Fart
Re: Clifford 50.5x remote wont start help
More info please...
MM&Y of car?
When you say "crank up n just die" does that mean the engine starts, runs for a bit then stalls?
By "crank then stop" do you mean the engine will turn over for a second or two but not fire at all and stop cranking, if so does it only cran the one time and stop or will it try and start the car 3 times and then stop trying?
What is the "failed start/start shut down", [shutdown diagnostics... http://www.directeddealers.com/manua..._05-06post.pdf page 53] playback telling you? 94
MM&Y of car?
More info please...
MM&Y of car?
MM&Y of car?
sry its an 2005 acura rsx-s
the 2nd one lol, u can hear the engine try to start but it doesnt fire up...it trys to crank up 3 times n then after that it stops
Old Fart
What type, [make and model] of immobilizer bypass module are you using?
If you did program tach check and see if security light, in instrument cluster, is flashing when engine is cranking during remote start, if so, stick key in ign., do not turn on, and try remote start again. 94
hey i got the matrix 12.5x yesterday and supposably i heard its good alarm very sensitive but idk if i hve to set it up as sensitive or what??! cuz right now the alarm doesnt sound off for ****! isnt it suppose to sound even if u get close to it? this wont wont sound even if i sart knockin on the car n shakin it around??? and is it suppose to have remote start also? i thought it was before i bought it cuz in the lil key that comes with it its an led key and it has a **** load of crap jus im not sure if it not working becuz idk how to use the remote or becuz its a shitty alarm that wont sound for crap unless i hit the car hard! ??
Old Fart
or if you do not have an bypass, it might be cause its getting cold and you need to program it to crank a bit more.
corked1260
11-19-2007 08:28 AM
blackccoupe
Audio / Security / Video
01-25-2007 04:06 PM
crxcess
06-10-2006 06:05 AM
