Bridging my Pioneer GM-X564 ?
Im trying to figure out how to bridge my 10" sub on this amp.
I dont know if I have it connect right....
Im using CH A for the sub..
Anyone tell me what is the proper way ?
Is channel A the top row and Channel B the bottom ?
thanks
Pioneer GM-X564 50W x 4 Car Amp at Crutchfield.com
thanks
From the picture, you can only bridge the L+ on Ch A and the L- on Ch B; or; R- on Ch A and R+ on Ch B.
To bridge one sub, I'm really not too sure on how you'd connect the RCA's. I guess one way would be to run one set of RCA's from the deck, then a pair of "Y" adapters to connect both the A & B inputs.
Re: (B18C_EJ8)
right now I have it bridged on L+ and R- On Channel A (top row)
is this correct ?
channel A is the top row and channel B is the bottom row.
I think the amp diagram is a lil misleading because there is a line that joins the + & - on there..
Modified by Rob. at 2:19 PM 4/13/2008
is this correct ?
Old Fart
Re: Bridging my Pioneer GM-X564 ? (Rob.)
Ch A is the top row, use it for the high-pass.
Ch B is the bottom row, connect left neg.(-) and right pos.(+) for bridged mono output, [on bottom row neg.(-) is 2nd from the left and pos.(+) is 4th from the left.
Plug in both sets of RCAs and place selector switch to 4ch.
This may work... http://www.pioneerelectronics....0.pdf page 3, "3ch mode". 94
w1ck3dR
Audio / Security / Video
11-22-2006 10:41 AM
