Stock radio w/my system
Old 01-26-2006, 10:33 PM
Dutch-VTEC's Avatar
Default Stock radio w/my system
I was getting ready to put my system in, I have a pioneer deck.(dont want to use, try to keep it stock and clean.)
I was wondering if there is a stock radio which plays cassets that has the rca wires for the amp.
Searched but nothing came up.
Old 01-27-2006, 01:14 AM
john666's Avatar
Default Re: Stock radio w/my system (TeamDoubleClutch)
with any stock stereo im guessing honda/acura. there arent going to be rca outputs.. you can buy a hi-low converter and use that to hook up your amps. they are available at any car stereo shop or even walmart.
http://www.walmart.com/catalog...63065
Old 01-27-2006, 09:06 AM
Dutch-VTEC's Avatar
Default Re: Stock radio w/my system (john666)
Cool, dont know if it will work because it only handles 80 watts. I plan on using around a thousand watts for my twelve. I will have to check to see if they have some that handle higher watts.
Ive seen on some ford radios where you can hook rca cables up to the stock radio.
That was the biggest reason why I was wondering.
Old 01-27-2006, 09:34 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamDoubleClutch &raquo;</TD></TR><TR><TD CLASS="quote">Cool, dont know if it will work because it only handles 80 watts. I plan on using around a thousand watts for my twelve. I will have to check to see if they have some that handle higher watts.
That was the biggest reason why I was wondering.</TD></TR></TABLE> All the high to low level adapts. will work on the oem HUs it has nothing to do with output wattage of your amp/s, some amps even have speaker inputs on them, a good speaker to RCA adapt. will cost a few $$, something like this... http://www.scosche.com/scosche...OC-80 if all you need is one set of RCAs for a sub amp or this if your amping everything.... http://www.scosche.com/scosche...SLC-4 the 80watts is input max and as your oem HU will not get close to that you will have no worries. 94
Old 01-27-2006, 12:44 PM
Dutch-VTEC's Avatar
Default Re: Stock radio w/my system (fcm)
Thanks for the info, saved me from doing alot of running around.
silentballer
Acura TSX
03-31-2007 09:55 AM
NsX_CrX
Audio / Security / Video
14
11-24-2006 09:32 AM
Defcon2030
12-13-2005 07:09 AM
1998hondaaccord
02-08-2005 11:00 PM
Quick Reply: Stock radio w/my system
