arm/disarm flashing and trunk pop ?
ALARM : CLIFFORD 5906X
CAR : 1997 acura integra
Clifford - 5906X
My lights, when arming and disarming stopped flashing one day. What do i check or do to fix this?
also, i was thinking about getting the DEI trunk popper, how would i hook that up? ( wire wise, i can figure out the mechanical part. )
Clifford - 5906X
Re: arm/disarm flashing and trunk pop ?
How To: Wireless Trunk Release - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
i found the fuse in the brain. i put in a new, same amp fuse and every time i click my remote once it breaks the circuit... i did however before this, rewired my entire headlight. ( jdm front integra. ) if i were to put in a bigger fuse amp would that be okay? so instead of the 15 can i put a 30? or will that mess shiiit up?
You need to check your wiring, something isn't right.
DO NOT put a higher amp fuse it's place. It's a 15amp for a reason. The fuse is designed to pop before damaging the circuits. If you put a 30amp in it's place you could end up permanently damaging the brain.
slowslow
Audio / Security / Video
10-08-2008 01:04 AM
Black R
01-12-2006 01:03 PM
