Speakers for the Integra?
Old 05-18-2002, 10:20 AM
Understeer's Avatar
Default Speakers for the Integra?
The fronts and rear are 6.5" inch right?
I was thinking of going with 6.5"s Alpine Type R speakers for the front.
Will these be good? What else is good?
Old 05-18-2002, 11:50 AM
94WhiteGSR's Avatar
Default Re: Speakers for the Integra? (EFJAY)
there actually a 6 in speaker and get the alpine r's there great thats what i have
Old 05-18-2002, 12:30 PM
Understeer's Avatar
Default Re: Speakers for the Integra? (94WhiteGSR)
For Integra year 94-97?? I thought they were 6.5"?
Old 05-18-2002, 01:22 PM
reno96teg's Avatar
i'd like to know specifics on integra speakers also. i'm looking to upgrade mine and want as little trouble as possible when doing so.
for those of you that have upgraded, what's the max thickness of speaker allowed in the door? any other issues. let us know please.
Old 05-18-2002, 02:59 PM
TexTeg's Avatar
Default Re: Speakers for the Integra? (reno96teg)
6.5" is the speaker size for front/rear of your car... But those alpine type r's are 6". Thats what he meant. You will need to make a custom spacer for the front to make the speaker fit right. No biggie, if you need help on that, let me know.
Old 05-18-2002, 03:02 PM
TexTeg's Avatar
I don't think you'll find a 6" component or 6.5" co-ax speaker that won't fit in that door. You will just need to make a custom spacer at worst which really isn't too difficult if you have a jigsaw.
Old 05-18-2002, 03:05 PM
New User
HondaCivicEx98's Avatar
What he meant was, the teg has 6.5 front speakers but seriously, if u compare them to aftermarket 6.5 speakers, u will find that the stock 6.5 are very small, also in terms of diameter, and u could consider them as 6". Those alpine are 6.5.
Old 05-18-2002, 05:04 PM
TexTeg's Avatar
Default Re: Speakers for the Integra? (HondaCivicEx98)
My bad, you are right... Thought the alpine comps were like diamond audio comps in that they only make 6" and 5". Either way, you will be needing a spacer to make it fit right.
Old 05-18-2002, 05:43 PM
Understeer's Avatar
Default Re: Speakers for the Integra? (TexTeg)
Sorry if this is a noobie question, but what does a spacer look like? Does it cover the left over .5 inch?
Old 05-18-2002, 05:57 PM
TexTeg's Avatar
You know how the speaker sits in a speaker basket right? Well, that speaker basket is quite shallow and most aftermarket speakers are entirely too large to fit properly in that basket. So you need to modify it. What you could do is cut out the basket and leave just hte rim of hte basket. Then try and mount the speaker with that. Some of the time that will suffice, but some of the time, you need that basket rim to be thicker b/c the speaker still is too deep/wide for that hole in teh door. So you have to go buy some mdf, make a cut out exactly like the speaker rim basket and drill that into the same holes the old speaker basket fit into the car door. Then simply mount the speaker onto that new "spacer" made out of mdf. That should give enough room for the speaker to fit flush on teh mdf board. Hope that helped.
Old 05-20-2002, 04:29 AM
integra-modder's Avatar
I just installed mine the other day... (read my post, https://honda-tech.com/zerothread?id=183851)
Here is some info...the Alpine 6.5" require a mounting diameter of 5.75 inches, Acura's doors are 5.25. Thats a problem, so to resolve it, you have to make a 1 inch spacer. I high suggest finding 1 inch thick MFD, I only found 3/4" and then had to use a 1/4" sheet of hardwood to make 1 inch. Then just cut them out and use to mount.
Here are some pics
Old 05-20-2002, 08:18 PM
maxxdout's Avatar
Default Re: Speakers for the Integra? (integra-modder)
very nice construction idea. When i did mine a while for my rockfords i made someonthing similar. With some scrap plywood laying around the house. Didnt have a timplate or idea, just knew i needed to extend the speaker out to make it fit. Worked out well after a few final trims with the jig saw. Nice job on the construction.
Old 05-21-2002, 07:00 PM
Default Re: Speakers for the Integra? (maxxdout)
thanks...and if anyone ever thought of buying that little roto zip tool....DONT
that thing is a piece of dangerous **** that has blades that tend to break apart and fly at things (hopefully not you or other things of great value).
OBSESSED
Audio / Security / Video
04-16-2009 02:20 PM
JDMThoughts
12-14-2005 05:20 PM
All Motor EH2
01-03-2005 01:49 PM
Dirt
02-23-2002 01:56 PM
MRDC2
05-22-2001 06:46 PM
Quick Reply: Speakers for the Integra?
