Ground Wire location for DC?
Old 06-28-2009, 09:58 PM
MilanoRedDashR's Avatar
Default Ground Wire location for DC?
My Amp in my gsr keeps shutting off. I'm pretty sure it's the ground wire, because I've had similar problems in other cars with the ground, and so I've narrowed it down to the ground wire. I don't know where to locate the Ground in the DC. Right now I'm just using a bolt under the carpet in the back, but obviously thats not the best. Is there something I need to know about the ground, or simply just find a better ground? ALso, what is the best bolt to use for the ground in our Integras? Thanks guys.
Old 06-28-2009, 10:11 PM
dohcvtak's Avatar
Default Re: Ground Wire location for DC?
the stock bolts are decent have u tried sanding down to bare metal and using a thicker yet shorten gauge wire
Old 06-28-2009, 10:13 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I doubt its the ground wire in the engine bay. List what consiest of your sound system. amps make and model and rating. Speakers and subs dvc and all. All grounds on the amps should be bolted down with its own bolt or screwed and the paint sanded down to metal.
Old 06-28-2009, 10:50 PM
Its just a ground to my rear amp. I'm going to try and sand down the paint and make its own bolt. sorry, should have been more specific. Right now it's just hooked up to one of the stock bolts.
Old 06-29-2009, 05:50 AM
fcm
Old Fart
fcm's Avatar
You can use the stock bolt, [depending on where/what it is] as long as ground lead terminal is making direct contact, [bare metal] with the cars floor pan. 94
Old 06-29-2009, 10:51 AM
If I sanded down the paint, and used a self taper and a washer, would that be good?
Old 06-29-2009, 04:17 PM
fcm
Old Fart
fcm's Avatar
I am no fan of self tappers, they break the rust barrier and because they are going into the thin metal of the cars floor board you can't put much torque on them so they tens to loosen up over time.
With that said a self tapper will work, but why drill a hole in your cars floor pan if you don't have to?
There are more then a few bolts and studs with nuts going into the cars floor pan I always use one of them, rear seat and seat belt bolts work great, just make sure the ground terminal, [ring terminal] is making contact with bare metal. 94
Old 06-29-2009, 11:47 PM
I did end up using the seat belt bolt. However, I was using that before and it didn't work good. This time I sanded off some of the paint and Hopefully that will work. I'm in my last effort, after this I'm taking it to an audio shop to have them set me up with a ground.
Old 06-30-2009, 12:17 PM
Tayter's Avatar
what is the power RMS rating of your amp and what gauge of wire are you using? how long is your ground?
Old 06-30-2009, 01:54 PM
Master Detailer
98civdx's Avatar
should be ok
but you could have just used the bolt that holds your back seat down.
Old 06-30-2009, 11:46 PM
My ground wire is only about 2-3 feet long. And I'm not sure what gauge of wire I'm using to be honest. All I remember is that I bought wire that was rated to handle my set up. I'll look tomorrow and give all the details. I'm thinking that it is something other than my ground wire, because my ground is really solid.
Old 07-01-2009, 09:04 AM
Old 07-01-2009, 05:29 PM
I'm going to list what I have as soon as I get the energy to check.
Old 07-01-2009, 06:34 PM
luisrblue's Avatar
had same problem in my ls. i connected the ground wire to the bolt in the strut bar, worked great.
(not my pic but too lazy to go out to car)
Old 07-02-2009, 09:35 PM
I think I know what bolt you used. I can't remember why I didn't use that, maybe because I didn't like how the wire looked.. I like it to look really clean. I guess I could run it all the way down, under the plastic, under the carpet, and then back up the small whole in the carpet in the center behind the seat.
Old 07-03-2009, 05:44 AM
fcm
Old Fart
fcm's Avatar
Get us the rest of the info, amp model, wire gauge.
Although shock tower studs are OK they are not a direct connection to the cars floor pan and the best possible ground is to the cars floor pan.
Your ground is longer then preferable but it should not be the cause of your problem, if it can be shortened by rerouting or remounting the amp do so, under 18" is preferable although the shorter the better.
Question...
What type and size of fuse are you using on amps power lead?
Again...
Make and model of amp?
Make and model of speakers/sub(s) it is driving?
Gauge of power cable?
Type and size of fuse?
We really need the above questions answered to be able to help. 94
lsvtechatchy
07-23-2010 07:45 AM
wegotmorrison
06-16-2010 10:47 PM
thejacka
Audio / Security / Video
07-10-2006 11:03 PM
juniordc2
22
07-18-2004 09:58 AM
TAG
07-23-2002 03:19 AM
Quick Reply: Ground Wire location for DC?
