2007 Honda Fit radio removal? - Honda-Tech
Old 04-26-2008, 05:45 AM   #1
Russell418's Avatar
Default 2007 Honda Fit radio removal?
How do you remove the stock radio out of a 2007 Honda Fit??? I know that there are 7 clips behind the unit, but is there more to do than just pull it out? Please help, if anyone has a clue.
Russell418 is offline   Reply With Quote
Old 04-26-2008, 11:35 AM   #2
fcm
Old Fart
fcm's Avatar
Default Re: 2007 Honda Fit radio removal? (Russell418)
fcm is offline   Reply With Quote
Old 04-26-2008, 03:11 PM   #3
Russell418's Avatar
Default Re: 2007 Honda Fit radio removal? (fcm)
I will try these steps as soon as I get some time. I will update this once I've gone through the steps. Thanks a lot for the help.
Old 04-27-2008, 07:34 AM   #4
Russell418's Avatar
It worked! A very big thanks to you! I had read no where previously of 2 bolts that needed to be removed. (Note to anyone who tries to follow the same directions from the removal/install. The bolts are 8mm and not 10mm.) Thanks a lot and take care!
1986-1998 Honda/Acura Radio Harness (To Wire Up Aftermarket Radio) BlueIntegraBoy For Sale 9 06-21-2008 12:17 PM
help radio trim evoalf Honda Fit 2 02-27-2008 05:17 PM
03 Honda Civic cd player Removal Deerslayer Audio / Security / Video 2 09-15-2004 07:50 PM
How do you remove the oem radio out of a 1990 integra? deeice30 Acura Integra 6 10-15-2003 02:43 PM
removal of stock radio mrod006 Audio / Security / Video 3 11-08-2002 12:21 PM
Tags
2007, 2008, 2009, audio, fit, honda, install, installation, radio, removal, remove, removing, replacement, stereo, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
