2005 RL bose stock sound system troubles
just picked this up and starting to find bunch of bullsheets allover the car
first off someone installed 15 dollar sony speakers and used the rubber surround as a baffle around speakers.
removed the subwoofer also.
I had a spare one so I plug it in and no sound
take the amp apart and looks like condensation damage
now the questions
1 since this car has an active noise cancelling system, how will it affect the noise cancelling system if I install aftermarket system.
assuming that its tuned with specific speakers or is it continuously adjusting from mic feedback and adapt to aftermarket speakers on its own?
2 the nav unit is a bit funky .. it keept the settings like radio presets and EQ preset in memory but it resets things like menu color and that annoying voice guide that tells you what button you just pressed every time you press it
I checked the fuses and they seem to be ok.
battery seems to be ok also
now the questions
Re: 2005 RL bose stock sound system troubles
Hi,I am not tech savy, but I'd like to help, first questions, it depends, some aftermarket system will be compatible with the original system, so after installing the aftermarket one it will still works the same and vice visa. Second question, an aftermarket system such as the Seicane will include a new gps which will be more easy to use.
figured out
lol was just bunch of bs the whole system was hacked up now everything works speakers were missing. amp was damaged sub was missing etc
put Harman kardon speakers from c class instead of bose
resoldered circuit board had cold solder
wired up the sub. everything works now.
this car is loaded with features.
had to program the key#2 for the radio to keep settings
cityslicker1606
Audio / Security / Video
45
04-18-2010 08:04 AM
