2001 Integra Radio pin-out - Honda-Tech
Old 10-14-2009, 01:39 PM   #1
Default 2001 Integra Radio pin-out
Im trying to put a radio from a 1998 Integra into my 01 ITR. I plug it in and the anti-theft light blinks but I get no power when I push the button. I have the code and what not but I think the problem may be with the harness. The harness is kinda hacked up and some wires are capped. Does anyone have a pin-out for the plug that I could use to re-wire the plug?
thundernoodle is offline   Reply With Quote
Old 10-14-2009, 03:36 PM   #2
fcm
Old Fart
fcm's Avatar
Default Re: 2001 Integra Radio pin-out
http://www.installdr.com/Harnesses/HA-Wiring.pdf, your 01 ITR may or may not use same plug as the 98 HU, although you did say "I plug it in and the anti-theft light blinks", did you use a plug that came with the HU or one that was still in the 01 ITR,
What color are the wires that are "capped"? 94
fcm is offline   Reply With Quote
Old 10-15-2009, 08:29 AM   #3
Hmm. I used the one from the ITR. The ones that are capped are; actually spilts off of some of the regular wires. At some point someone had a system in this car and I think they ran extra wires from certain OEM wires. All of the capped one go into a plug with another wire that comes out of the main harness.
Old 10-15-2009, 09:02 AM   #4
fcm
Old Fart
fcm's Avatar
Quote:
Can you take a pix and post it?
I need to know what the wires that are capped and running from a plug are and what wire from the main harness is connected.
Could the plug be the stock radio plug still hanging by one of it's leads, [not used by last guy] what color is that one lead. does the plug look like either one of the ones in the link
Which plug is it, [plugged into the 01 HU] the first one, [1986-1997/98] or second one, [1997-1998 and newer] in the link I gave you?
The problem is that on some Integra the 1986-1997/98 plug/radio harness was used all the way to 2001 and on other Integra the change over was made in 1997/98.
As you can see in the link, most of the wiring is the same, [color-designation], be careful with the brown/white, power ant. and right rear speaker neg.(-) are the same color, your 01 HU plug, [if newer type] may have a red lead, your 98 Integra radio harness, [if older type] will not have the red lead, red is illumination ground from "Dash Lights Brightness Controller" neither the illumination power, red/black or ground, [red] are shown on the wire guide in link. 94
looking engine harness pinout k20rex Honda CRX / EF Civic (1988 - 1991) 1 10-29-2011 09:00 AM
5g JDM ecu pin-out vinuneuro Honda Prelude 6 05-25-2009 01:54 PM
HELP!!! can you identify this obd2a harness and give me a pinout for it? nello a. Honda Civic / Del Sol (1992 - 2000) 5 12-24-2008 01:20 AM
wire harness question B18CUL8R Acura Integra 6 12-23-2008 10:58 AM
Anyone have the pin-out of the stock stereo harness? Devine Honda S2000 2 11-30-2004 09:03 PM
Tags
2001, accord, chrysler, civic, diagram, harness, honda, integra, pin, pinout, plug, plugs, radio, sound, stereo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
