2 way pager alarm remote problem
Old 09-13-2005, 06:03 PM
8krdline's Avatar
Default 2 way pager alarm remote problem
I have a viper 690xv on my car and today the remote is not working. No buttons on the remote work, but it shows and vibrates when a door is opened. It shows the remote as having signal but when you press a button it shows no signal. And because of the started kill I cant start my car. Any ideas what could cause the remote to do this? and how can I start the car, unplug the brain?
Old 09-13-2005, 09:19 PM
kcem1's Avatar
Default Re: 2 way pager alarm remote problem (8krdline)
you can start the car by putting it in valet mode.
1-locate valet switch
2-turn key to on postion
3-take key out
4-press valet switch
5-make sure led is solid(if it is proceed to step 6 if not go back to 1)
6-start car
as far as your remote not working you gonna need a new unless you can solder the smallest solder connection ever but as long as the alarm was installed by a certified d.e.i. dealer you have a life time warranty.
Old 09-14-2005, 10:43 AM
vicn77's Avatar
Default Re: 2 way pager alarm remote problem (kcem1)
8krdline is correct about disarming the alarm, but i don't believe dei has a lifetime warranty on the remotes. it is usually the brain of the alarm.
Old 09-14-2005, 11:28 AM
fcm
Old Fart
fcm's Avatar
Default Re: 2 way pager alarm remote problem (vicn77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vicn77 &raquo;</TD></TR><TR><TD CLASS="quote">8krdline is correct about disarming the alarm, but i don't believe dei has a lifetime warranty on the remotes. it is usually the brain of the alarm.
</TD></TR></TABLE> You are correct, one year on the remote, but you are both incorrect about disarming without remote, it's turn on ign. and within 15 sec. press the valet button the preset number of times, [1 to 5] after 5 sec. the alarm will disarm, if it does not disarm you waited to long, [15 sec.] or you have the wrong number of pulses, http://www.directed.com/guides...4.pdf I believe the default pulse is 1, http://www.directed.com/guides/ogs.asp 94
Old 09-14-2005, 12:44 PM
8krdline's Avatar
Default Re: 2 way pager alarm remote problem (fcm)
well i couldnt get the valet switch to work so i had to unplug the brain. Looks like I'm going to be looking for a new alarm this weekend, possibly the 791xv if they dont want a rediculous price for it
Old 09-14-2005, 09:10 PM
EGPrelude's Avatar
If you have the white remote with grey backing, (which I believe you should with a 690xv), and if you got it installed at an authorized dealer, I believe those have somewhat of an extended warranty
The reason being is that those white remotes are somewhat defective and thats why DEI came out with the new remotes so quickly after the old ones. You can try calling up DEI. They may be able to still replace the remote even those its out of its 1 year warranty
Old 09-15-2005, 04:24 AM
8krdline's Avatar
Default Re: (EGPrelude)
well the thing is it was installed by a friend of mine. He used to work at bestbuy installing alarms and wasnt at the time when he installed mine, so I dont think that they will cover it.
Old 09-15-2005, 05:21 AM
JDMoMo
Guest
Posts: n/a
Default Re: (8krdline)
hmm...I've heard some shady **** about that 790 so I went w/ 791 instead but that sux too so I got the clifford remote for $75 brand new on ebay and using that. It's better and has a better range for some reason over the viper remotes
2000siturboR
Audio / Security / Video
02-25-2009 07:51 AM
Dr. Willy
08-11-2008 12:53 AM
ZacCarter
10-14-2007 09:29 AM
type B16
01-08-2007 04:49 PM
jameskersten1
05-24-2004 09:58 PM
Quick Reply: 2 way pager alarm remote problem
