resistor spark plugs?
Old 08-01-2004, 04:10 PM
C_H_A_D's Avatar
Default resistor spark plugs?
my hu makes a howling noise when rpm's rise i have a book from crutchfield says it most likely is my plgs or my distributar or coil says i need resistor type plugs what is difference in resistor plugs and regular? Shielded carbon core spark plug wires? please help also any body recomend any good spark plug's and wires like theese for a 99 accord ex v6
Old 08-01-2004, 04:20 PM
C_H_A_D's Avatar
Default Re: resistor spark plugs? (mood513doom)
Also i hear this howliong noise with engine off put the ignition turned to accesorie is it possible its the ignition its self and not bad spark plugs?
Old 08-02-2004, 10:11 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood513doom &raquo;</TD></TR><TR><TD CLASS="quote">
Also i hear this howliong noise with engine off put the ignition turned to accesorie is it possible its the ignition its self and not bad spark plugs?</TD></TR></TABLE> If the the noies is there when engine is off its not the plugs, I would check grounds on all aftermarket HU and amps.
hope this helps. 94
Old 08-02-2004, 01:59 PM
teamxtant's Avatar
Default Re: resistor spark plugs? (fcm)
First things first,
1. What kind of car
2. What kind of deck is it.
3. Do you have any amps or eqs.
4. Do you have any neon lights or voltage converter
I have worked on a lot of accords and i have never had this problem. If you used the factory wiring with an installation harness i can't think of anything going wrong. However, I am assuming that you have an amp in your car because 90% of cars with noise have amps in em.
Old 08-02-2004, 03:01 PM
C_H_A_D's Avatar
Default Re: resistor spark plugs? (teamxtant)
99 accord ex v6
pioneer deh-p9600mp
2 amps one 800 watt four chnnle pyle and a 2000 watt pyle 2 channel
2 capacitors
no neon or converters
Old 08-02-2004, 03:47 PM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood513doom &raquo;</TD></TR><TR><TD CLASS="quote">99 accord ex v6
pioneer deh-p9600mp
2 capacitors
no neon or converters</TD></TR></TABLE> I have heard of so many noise problems with Pioneer HU plugged into non Pioneer amps, I'm beginning to think Pioneer does it purposely 94
Old 08-02-2004, 04:24 PM
teamxtant's Avatar
First you have to find out where the noise is coming from, either your head unit, the rcas, or the amp itself. Read the audio FAQs at the top of the forum, there is a lot of good help in there. But I am will to bet the its coming from your HU through the rcas. Run your rcas down the opposite side of the car away from factory wire looms and the power wires coming from your battery. It works, not all the time, but it helps quite a bit.
Old 08-02-2004, 06:48 PM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood513doom &raquo;</TD></TR><TR><TD CLASS="quote">2 amps one 800 watt four chnnle pyle and a 2000 watt pyle 2 channel
problem(s) spotted!
Old 08-04-2004, 12:46 PM
C_H_A_D's Avatar
my power cable is running under the center of the car, i tried connecting my rca's going over my seats to the amps and it sounds the same, my friend has his battrer in the trunk and he gests and howling noise and it real quiet if he moves his amp and battery further away it gets quiter and loudewr if closer. I do know its either the hu or the rca i pulled my car close to a friends and hooked up his rca's and no problem. I just installed this pioneer cd player because i thought it was the cd player i had before causeing this problem and it still does it. i had this cd player for 7 months before this problem started happening
kte324
03-15-2010 09:36 AM
deca_b16
05-19-2007 09:52 AM
revhi
Honda S2000
10-23-2006 08:23 PM
Turbo-charged
06-25-2006 07:04 PM
C_H_A_D
08-02-2004 03:02 PM
Quick Reply: resistor spark plugs?
