amp intall kits
Old 09-15-2004, 05:24 PM
pezzy's Avatar
Default amp intall kits
i have a bunch of 8 gauge wire and 16 gauge wire..but i dont ahve any of the terminals to connect it to the amp...
i also dont have the fuse thing that every amp install kit includes
should i just get the terminals alone and then put it on the wire? what about the fuse? or should i just go with a amp kit?
if to go by amp kit..where would i buy one?
Old 09-15-2004, 07:36 PM
lotas's Avatar
Default Re: amp intall kits (pezzy)
uh yeah you can just go buy the terminals at like napa auto parts and then crimp them on. (gotta have crimpers though, make sure you check for tight connection after crimping)
amp kits are handy cause they have all the gauge wire you need, and its the proper gauge (according to the wattage of the amp, the amp kit will be rated. 350watt amp kit, etc) you can get them at circuit city, best buy, etc. I believe Wal-Mart has the cheapest ones, and they arent too bad. never seen them though.
Old 09-15-2004, 08:40 PM
Odessa's Avatar
Default Re: amp intall kits (lotas)
I never pay attention to the watts on the amp kit. I just go by the power cable gauge and the fuse size...
Don't buy the kit if you already have everything except fuse holder, the fuse itself and the terminals.
Old 09-15-2004, 09:25 PM
kontai69's Avatar
This website has a calculator to determine exactly what gauge of wire and fuse size you will need, factoring in length of wire and the amp's power output...
http://www.bcae1.com/wire.htm
As far as ring terminals, any auto parts or hardware store has a good selection. Fuse holders can be purchased at Radio Shack or even WalMart.
92civicx
Audio / Security / Video
02-07-2008 04:36 PM
EvenStar
10
01-25-2007 07:55 AM
skrewdriver88
12-26-2005 12:28 PM
rodimus
12-17-2002 05:27 PM
Quick Reply: amp intall kits
