0 db and +3db button on infinity 6022 6.5"
Old 08-27-2007, 05:12 PM
allricedout's Avatar
Default 0 db and +3db button on infinity 6022 6.5"
what does this mean and what do you reccommend, pushing it in to the +3db position? they are 6.5's on a 92 civic i need help asap before i put the door panel back on.
Old 08-27-2007, 06:15 PM
fcm
Old Fart
fcm's Avatar
Default Re: 0 db and +3db button on infinity 6022 6.5" (allricedout)
I will increase the output of the tweeter by 3dB...
• Tweeter level adjustment - The 6022i also features a tweeter level adjustment located on the front of the speaker and can be set at the reference level of 0dB. If the speakers are located low in the doors or if you are looking for a brighter sound, set the tweeter at +3dB. The same goes for the 6022si. 94
Old 08-27-2007, 06:35 PM
Default Re: 0 db and +3db button on infinity 6022 6.5" (fcm)
thanks i pushed the button in to the +3 db setting, i need all the fine tweeter sound i can get because i just have two of these and the rest of my car is gutted, all in all it sounds good with a decent amount of bass.... the worker at best buy showed me how these infinitys outperform other brands by a huge margin.... all in all i am satisfied with my 120$ spent on these, anyways thanks.
o yeah and what does "db" stand for exactly? or is it just a frequency?
Old 08-27-2007, 06:54 PM
B18C_EJ8's Avatar
^^ DB stands for decibels... A unit of sound level measurement.
Old 08-28-2007, 06:04 AM
slowSOHCvtec's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">^^ DB stands for decibels... A unit of sound level measurement. </TD></TR></TABLE>
actually it is a unitless measurement, it's a ratio. However most acoustic and electronics use this unit for measurements ie dBA, dBV, dBW, SPL, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> I will increase the output of the tweeter by 3dB...
• Tweeter level adjustment - The 6022i also features a tweeter level adjustment located on the front of the speaker and can be set at the reference level of 0dB. If the speakers are located low in the doors or if you are looking for a brighter sound, set the tweeter at +3dB. The same goes for the 6022si. 94</TD></TR></TABLE>
correct, it will increase the apparent sound of the tweeter output
Old 08-28-2007, 08:03 AM
suspendedHatch's Avatar
3db is considered to be the smallest amount of change in volume that is detectable.
I always leave it at 0 and depend on the crossover adjustments primarily and then fall back on the equalizer. Infinity's are already bright as it is.
Old 08-28-2007, 05:36 PM
Default Re: 0 db and +3db button on infinity 6022 6.5" (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">3db is considered to be the smallest amount of change in volume that is detectable.
I always leave it at 0 and depend on the crossover adjustments primarily and then fall back on the equalizer. Infinity's are already bright as it is.</TD></TR></TABLE>
yeah, i was thinking of leaving them in the 0 db position and using my alpine head unit to fine tune it from there... i can access the tiny button through the vents in the speaker vents in the door panel with a feeler guage or something similar.
hi ho silver
Audio / Security / Video
06-14-2010 07:45 AM
doggworld1233
10
03-13-2007 09:47 PM
95civickid
09-12-2005 02:47 PM
nsxxtreme
10
09-21-2002 12:44 PM
Kellindal
01-29-2002 02:31 PM
Quick Reply: 0 db and +3db button on infinity 6022 6.5"
