"The World Has and Never Will Require 4ws" Rywire/Bisimoto/HybridRacing - Page 3 - Honda-Tech
Old 02-25-2013, 03:38 PM   #51
Default Re: "The World Has and Never Will Require 4ws" Rywire/Bisimoto/HybridRacing
you mean the kaizenspeed balance shaft eliminator? if so, they've had that out for a while now.
732xghost is offline   Reply With Quote
Old 02-25-2013, 04:34 PM   #52
whitesihatch's Avatar
k series rbc mani would look great with this, but idk about the fitemnt.
whitesihatch is offline   Reply With Quote
Old 02-25-2013, 07:42 PM   #53
Quote:
Nope, their tensioners where either out of stock or not available when I put this motor together. It's been two years since I did this.
Quote:
4ws_Ryan is offline   Reply With Quote
Old 02-25-2013, 07:49 PM   #54
Started laying some pipe...
Had my good friend Brady help with this part. He is an electrician and bends pipe all day. These are all up to code. :p
Did the engine bay lines and realized my local parts store special brake master cylinder was going to clash with its goldish finish.
Sand blasted it and cleared it. Matches perfect again.
Started working on my fuel lines. This fabric/nylon coated hose is a pain in the **** to work with...
For those unfamiliar with the 4ws system you can see the steering shaft the runs to the rear steering box. Purely mechanical system very simply!
Line to the fuel rail
Old 02-26-2013, 03:16 PM   #55
Quote:
probably out of stock. when i pieced together my H22 swap 4 years ago that was on my list and i almost pulled the trigger, but kept reading conflicting stories of it's reliability for daily driving.
nice update!
Old 02-26-2013, 03:33 PM   #56
EE2bitsk's Avatar
so bad ***.
EE2bitsk is offline   Reply With Quote
Old 02-27-2013, 11:42 PM   #57
92civiceg9gsr's Avatar
Very nice and thorough build on a unusual car to build. Props to you!
92civiceg9gsr is offline   Reply With Quote
Old 02-28-2013, 12:03 AM   #58
EK-MAX92's Avatar
Bad ***!
EK-MAX92 is offline   Reply With Quote
Old 03-04-2013, 04:36 PM   #59
nice update!
Yeah, who knows what will happen. I think I'll be perfectly fine with the OEM Auto. We shall see.
Quote:
Originally Posted by EE2bitsk View Post
so bad ***.
Quote:
Quote:
Originally Posted by EK-MAX92 View Post
Bad ***!
Thanks everybody appreciate it.
Been working on my manifold fitment recently here is what we came up with. (Big props to my friend Preston for the shave!)
Step 1: Buy Brand New RBC, test fit it before we get to crazy, looks like it was going to work when I bought it. So lets go for it.
Step 2: Get rid of the ugly mounting points for the stock plastic cover and all vacuum ports.
Step 3: Get that water pipe out of here
Step 4: Sand and smooth
Step 5: Weld everything shut
Step 6: Weld adapter plate on Which will give us the final product before powdercoat!
Step 7: Test fit
Fits like a dream, although I will need to do something with the throttle cable bracket. It is hitting the coolant temp sensor. :nervy:
Old 03-05-2013, 01:43 AM   #60
Earthworm Jim's Avatar
^^^^ Nice
Earthworm Jim is offline   Reply With Quote
Old 03-05-2013, 12:59 PM   #61
Dc2_ShowStopper's Avatar
nice in for updates
Dc2_ShowStopper is offline   Reply With Quote
Old 03-05-2013, 01:48 PM   #62
RussLaviolette's Avatar
Quote:
Originally Posted by Dc2_ShowStopper View Post
nice in for updates
The above updates were from yesterday.
RussLaviolette is offline   Reply With Quote
Old 04-03-2013, 05:08 PM   #63
Picked up some wheels and tires... apparently this is classified as dry rot now. Oh well replacing them anyways.
Was going to run Spoon Ridged Collars so I picked up a set for an eg/dc thinking it would work. They didn't, I think I need the DC5 kit, but I am going to save that for another day. Picked up some Spoon magnetic drain plugs also.
Subframe fresh from powdercoating
On, also with manifold powdercoated
Old 04-04-2013, 05:54 AM   #64
Gtimportfanatic's Avatar
to say this build is epic is an understatement. this is just F*cking awesome dude... so many details and such quality parts.
Gtimportfanatic is offline   Reply With Quote
Old 04-04-2013, 08:32 AM   #65
HOMEMADEPOWER's Avatar
Quote:
Keep up the good work and I cant wait to see this project at its finishing stage.
HOMEMADEPOWER is offline   Reply With Quote
Old 04-04-2013, 05:09 PM   #66
EJ1_Ex's Avatar
wow looks great!!
EJ1_Ex is offline   Reply With Quote
Old 04-04-2013, 07:31 PM   #67
zelseman's Avatar
Keep it up! My first car was a 3rd gen, they are a ton of fun stock. I can't imagine one fully worked over.
zelseman is offline   Reply With Quote
Old 04-04-2013, 07:41 PM   #68
Master Ninja
Eddie's Avatar
Wow great job so far. Honestly don't see enough of these car's being built.
Eddie is offline   Reply With Quote
Old 04-04-2013, 10:54 PM   #69
ChaseIntegra's Avatar
Holy moly! I just browsed through this but I subscribed! I'll be back to read it
ChaseIntegra is offline   Reply With Quote
Old 04-05-2013, 01:50 PM   #70
team1320_k26eg's Avatar
Nice build. In for updates
team1320_k26eg is offline   Reply With Quote
Old 04-10-2013, 01:39 AM   #71
wELLpLAYED77's Avatar
I like where you are going with this...
wELLpLAYED77 is offline   Reply With Quote
Old 04-10-2013, 03:55 AM   #72
1crazyk's Avatar
RBC looks good!
1crazyk is offline   Reply With Quote
Old 04-10-2013, 02:09 PM   #73
love how you chose the rbc, everything about this build is right on point!
Old 04-10-2013, 04:44 PM   #74
Brrraaaap!
Blaze45's Avatar
This is great! Thanks for sharing!
Blaze45 is offline   Reply With Quote
Old 08-26-2013, 11:36 AM   #75
Been a looooooong time since I've updated here.
16an fitting hose and ends to replace the standard radiator hoses.
Had my buddy work his magic on these, looks factory.
Had to relocate the temp sensor to keep it from hitting the throttle cable bracket
Also called Tim at Hybridracing for some more goodies, I am really excited to use this purchase...
"Bolt In" shifter
Also got the race cables and the required adapter bracket that bolts on the trans in place of the factory bracket
yeah yeah, missing a clip, but here you can see the adapter plate
Cables in the bay, harness in, intake manifold torqued down, fuel lines complete. playing around with the valve cover I suppose.
Installed bolted from the top
Little video, its very cold up here plus brand new = very tight. I'm sure it will loosen up after a little break in.
http://s46.beta.photobucket.co....html
Picked this bad boy up a loooooong time ago. Super excited I finally got my hands on a mint condition one!
Starter was also refinished
It was time to step up to coilovers as well
Current bay picture
SD FS: 17x7 Volk Racing AV3's 4ws_Ryan Wheels 10 05-23-2016 04:51 PM
77 Civic trailer build... Many Pics DOHCIVIC Classic Hondas 55 06-25-2012 08:03 AM
H24 Engine Setup! tamadrummer1120 For Sale 6 01-16-2012 06:08 PM
Fresh BA4 Pictures of a Fresh BA4(56k no) blahblah311 Honda / Acura 43 09-03-2009 01:35 PM
My 400+ whp Shaved INTEGRA First time posting Pics xtremeness101 Honda / Acura 78 01-21-2006 01:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
