Casey's 1992 Civic Si build
Old 08-23-2016, 03:23 PM
  #101
Casey's Avatar
Default Re: Casey's 1992 Civic Si build
Originally Posted by dsol
Subscribed for more!!
I use Rock Auto as well and have heard horrible things about the return process. Luckily I have had no issue...YET. (knock on wood) How big of a battle was it to get them to eat the shipping and fix the mistake? If you don't mind me asking.
it wasnt that bad once I was able to respond to a live person. I basically had to reply to an automated email I received when I emailed customer service. Once I explained I had pictures and it was a packaging error on the manufacturers end they responded. I sent the pics, within a half hour I had a return shipping label. Once they received the shipping confirmation that mine was on the way, they shipped the correct one
Old 08-23-2016, 04:10 PM
  #102
No Jodas
ShinsenTuner's Avatar
I never had a problem with rockauto customer service. Everything has always been quick and easy.
Old 08-24-2016, 05:12 AM
  #103
dsol's Avatar
I often wondered how they handle the warranty stuff also...but if it was that easy for you to handle that shipping error I can only assume it would be roughly the same for warranty/early part failure.
Thanks for the info! keep posting some progress.
Old 08-29-2016, 02:43 PM
  #104
Casey's Avatar
transmission is painted. I cleaned it up and scuffed it last time I was at my friends. He went ahead and painted it today since the weather was decent. It looks like it came out great. It was sent to me with the case and bell housing unbolted so that we could inspect. Synchros look great and had the quaife lsd as described
cleaned up the thermostat housing tube. It was in bad shape like the block. Media blasted it and sprayed it with my trusty krylon primer/paint in one. If it was something that was going to be taking a beating or seen in plain view I would have opted to powdercoat.
Old 08-30-2016, 05:38 PM
  #105
ajabbar's Avatar
What color did you paint it?
Old 08-30-2016, 06:47 PM
  #106
Brice.Hayden's Avatar
Silver and black.
Old 08-31-2016, 09:46 AM
  #107
Casey's Avatar
lol
used this for the block and trans
and this for the black pieces ive done (coolant tube, t bracket)
Old 08-31-2016, 11:08 AM
  #108
WeakSi's Avatar
Silver and black.
Ahhh yes the old "what color is this" Honda-Tech response :p
Old 08-31-2016, 04:49 PM
  #109
ajabbar's Avatar
Thanks for info Casey! Great build!
Old 09-01-2016, 04:27 PM
  #110
"Samurai gold"
Old 09-06-2016, 12:05 PM
  #111
Casey's Avatar
a few more minor updates:
cleaned the header up a little bit with some barkeepers friend, 1000 and 1500 grit sandpaper. I wasnt going for a mirror finish but wanted an even look once it starts to color again and the stain/discoloration was bad before hand
started throwing some "samurai gold" bolts in the trans
and got my tires mounted
with any luck, I should have some real updates this weekend. The car is moved to the shop and parts should be going on
Old 09-06-2016, 01:05 PM
  #112
Shit Posts: 15
JDMswagSerf's Avatar
Headers came out great!
Old 09-06-2016, 01:07 PM
  #113
scottp11's Avatar
x2
Old 09-06-2016, 01:33 PM
  #114
On vacation
testify's Avatar
I'm not liking the wheels, but the rest of the build is perfection.
Old 09-07-2016, 05:38 AM
  #115
WhiteSlips's Avatar
Looking good! I love the RNRs personally and that header is making me want to polish mine instead of doing the "brushed" finish.
Old 09-07-2016, 07:36 AM
  #116
Black/red wheels on red cars look amazing.
Old 09-07-2016, 11:11 AM
  #117
Casey's Avatar
Originally Posted by scottp11
x2
thanks!
thanks! first person ive ran into that doesnt like black/red rnr but to each their own. definitely wont be the only set of wheels this car gets, just will be a while before i have multiple sets
thanks sir. The header is a shiny brushed honestly, i wouldnt consider it a full polish. ive found theres a very high ramp of diminishing returns when it comes to polishing something that is going to discolor and oxidize relatively soon anyway. for the time i spent though, i wouldnt mind shining it up again in the future
truth. going for that classic look but i want it all to look new. i cant wait till its done
Old 09-07-2016, 11:18 AM
  #118
No Jodas
He said samurai gold lol
Old 09-09-2016, 12:04 PM
  #119
bks84's Avatar
Awesome rebuild man!
Old 09-11-2016, 08:52 AM
  #120
Casey's Avatar
thanks everyone
Got some progress done on it this weekend. I didnt take a ton of pics though.
We tapped all the threads in the bay that are going to be used. With the new bolts it was nice having things go together with ease
Getting engine bay items reinstalled before the engine goes in
took the ABS module out under the dash and heater core. Drilled through the firewall with a hole saw to run the harness through
With the firewall grommet fitted and riveted in. This thing worked out perfectly. It covers the huge hole so that hot *** engine bay air wont cook my feet, and the rubber stretches enough to get the ECU side plugs through it without any issue.
With the rear motor mount in place the grommet is completely out of site
One blurry one with headlights and corners back in
I started on doing new undercoating and painting the rear brakes. Ill have pics of that next weekend once completed. Dont mind the steering rack and the lower subframe as I am ordering a manual rack and will be repainting the subframe. I originally was planning on leaving the rack in but its an eyesore at this point to me and it may as well get done while everything else is being replaced.
Old 09-11-2016, 11:46 AM
  #121
Master Ninja
Eddie's Avatar
Oh gawed that looks good
Old 09-11-2016, 01:11 PM
  #122
Josip.'s Avatar
red ones are allways the fastest. :D
Old 09-12-2016, 05:25 AM
  #123
WhiteSlips's Avatar
Looking good man! The zinc bolts are money.
Old 09-13-2016, 09:54 AM
  #124
OG Wagon's Avatar
Great work! Where did you source the new/replacement blue brake reservoir cover? The color doesn't appear to be OEM?
Old 09-13-2016, 09:57 AM
  #125
Casey's Avatar
thanks guys.
I purchased the master cylinder off an ebay vendor. Its not "Honda" but it is OEM Nissin. JHPUsa also sells them and depending on the batch they could be grey or blue topped
Quick Reply: Casey's 1992 Civic Si build
