y8 or z6 cam gear? (d16y8 block z6 head)
Old 05-15-2010, 01:37 PM
vtec8200's Avatar
Default y8 or z6 cam gear? (d16y8 block z6 head)
which cam gear do I use with a d16y8 block and z6 head?
thanks!
Old 05-19-2010, 10:13 PM
lunch_box_4_life's Avatar
Default Re: y8 or z6 cam gear? (d16y8 block z6 head)
you def. want to use the cam gear that is mated to the cam if your useing a cam from a z6 use the z6 gear the y8 gear is set like 8 degrees different than the z6
Old 05-20-2010, 02:33 PM
vtec8200's Avatar
Thank you.
And if I use an adjustable cam gear for a y8, how much do you need to retard the timing?
boun4door
10-21-2008 05:46 AM
nikolass
10-04-2006 08:33 AM
SOHC_MShue
02-07-2004 06:18 AM
Quick Reply: y8 or z6 cam gear? (d16y8 block z6 head)
