WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T
Old 06-11-2006, 05:49 PM
Dr.Octagon's Avatar
Default WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T
MY SETUP IS A B20B BOTTOM END WITH A GSR HEAD..
Old 06-11-2006, 06:02 PM
zCivic's Avatar
Default Re: WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T (Dr.Octagon)
22T is a Vtec one 19 is a ls/b20. You can use either one depending on timing belt. If 22T use a GSR belt if ls/b20 use the ls/b20 belt. I would suggest the 22T though.
Old 06-11-2006, 08:06 PM
brokeHonda's Avatar
Default Re: WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T (zCivic)
I believe the correct answer is the 22t pump. Decreases the odds of forming air pockets at high revs from frothing the coolant.
witch ≠ which
Old 06-11-2006, 08:47 PM
Dr.Octagon's Avatar
Default Re: WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T (brokeHonda)
looks like im off to buy a gsr timing belt tomorrow and slap the 22t back on..
thanks for the good help
Old 06-12-2006, 06:27 AM
mar778c's Avatar
Make sure your waterpump matchs your oil pump.
Old 06-12-2006, 07:42 AM
zCivic's Avatar
Default Re: WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your waterpump matchs your oil pump.</TD></TR></TABLE>
Huh oil pump doesn't make any difference on the timing belt or water pump. Pumps outsides are almost identical except OBD2 vtecs have the cyl position sensor on them. But if your this far in the build up hope you already have a vtec pump.
beaneg6
03-10-2009 04:08 AM
RTW DC2R
07-02-2004 07:07 AM
88B20CRX
04-17-2003 05:23 PM
gsrhatch22
07-03-2002 04:22 AM
1hottEG6
04-13-2002 04:33 PM
Quick Reply: WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T
